sarjo Posted March 29, 2006 Share Posted March 29, 2006 Has anybody changed their tailgate rubbers - mine are a bit worn and I've heard changing them can reduce the rear rattling not that I've heard much of that with the noise from the exhaust !!!!! A guy on ebay is selling them for about 30 quid a set - thought that might be a bit expensive for four rubber blocks!!?? Traders? Quote Link to comment Share on other sites More sharing options...
Jspec Germany Posted March 29, 2006 Share Posted March 29, 2006 Search 'boot rubbers'. Tons of threads on this,... and yes, that's expensive. Oh, and you only need two pieces. Quote Link to comment Share on other sites More sharing options...
Faye Posted March 29, 2006 Share Posted March 29, 2006 You can get them from Toyota for about £10 including the screws Quote Link to comment Share on other sites More sharing options...
markssupra Posted March 29, 2006 Share Posted March 29, 2006 Only problem you might have is if the screws are rusty and can be a pain in the ar*e to get out, but it does cure the annoying rattles and squeaks. I had to carefully drill out some of the screws and re tap the threads. check out this link from mkiv.com. http://www.mkiv.com/techarticles/hatch_rattle/index.html Quote Link to comment Share on other sites More sharing options...
Rob Davey Posted March 29, 2006 Share Posted March 29, 2006 The screws are held in with loctite. One side of mine came out easy the other i had to drill as i rounded off the screws (I was unaware of the damn loctite at that point!). Try and get some thinners in the screw thread to release the loctite and use the appropiate screw driver to limit an issues! Quote Link to comment Share on other sites More sharing options...
sarjo Posted March 29, 2006 Author Share Posted March 29, 2006 Thanks for the advice guys - will try that. They sound quite cheap from Toyota, and not doubting you but are you sure there's only two? Trip to Toyota coming up! Quote Link to comment Share on other sites More sharing options...
Rob Davey Posted March 29, 2006 Share Posted March 29, 2006 Only two. I stupidly bought the ones on the top of the boot, these are hard plastic and do not wear out at all! damn things were more expensive than the bottom ones! Quote Link to comment Share on other sites More sharing options...
Burna Posted March 29, 2006 Share Posted March 29, 2006 Also fit cap head screws so it will be alot easy the next time you want to change them. Quote Link to comment Share on other sites More sharing options...
Chiefgroover Posted March 29, 2006 Share Posted March 29, 2006 I have a pair, used for two years and pretty much as good as new. Quote Link to comment Share on other sites More sharing options...
