whitesupratt Posted March 28, 2006 Share Posted March 28, 2006 So as I have mentioned before, I am getting my mate to build me a straight through 3'' system straight off the turbos, therefore there wont be a flange/join to put a restrictor ring in...wondered, what diameter are 1bar/1.2bar rings, can;t I ge them to put a reduced section in the exhaust? Link to comment Share on other sites More sharing options...
SimonB Posted March 28, 2006 Share Posted March 28, 2006 How's that going to work at MOT time? The size of the ring totally depends on the size of your exhaust, how restrictive it is, and varies even from car to car. You'd need to adjust it until it was right. Link to comment Share on other sites More sharing options...
whitesupratt Posted March 28, 2006 Author Share Posted March 28, 2006 So how do people normaly know what restrictor ring to buy? MOT time will be ok, its cool Link to comment Share on other sites More sharing options...
SimonB Posted March 28, 2006 Share Posted March 28, 2006 They are made to a size that restricts to around 1.1BAR on a standard car with a 3 inch exhaust and 2 2.5 inch decats. Then you fit it and see what boost you get. If it's less than you want you whip it out and file it out a bit and try again. That's basically it! Link to comment Share on other sites More sharing options...
whitesupratt Posted March 28, 2006 Author Share Posted March 28, 2006 hmm, so what do u think i should do to restrict mine? Link to comment Share on other sites More sharing options...
