milocoon Posted March 25, 2006 Share Posted March 25, 2006 If Envy used the multipin plugs you can bypass the RLTC unit and eliminate that from being a possible fault. Simply unplug the TWO sets of plugs and swap the FEMALE plug over. Then you`re back on original wiring . Quote Link to comment Share on other sites More sharing options...
RedM Posted March 25, 2006 Author Share Posted March 25, 2006 Milo, I'll have to look in the morning. Too dark and the rain is persisting down! Quote Link to comment Share on other sites More sharing options...
Branners Posted March 25, 2006 Share Posted March 25, 2006 RLTC INSTALL might be the key here. Theres very limited space around the ECU and it has been seen on a number of cars that things get all squashed up in there and the ECU starts getting bad signals. I had a similar thing when I drove out to pick up my brother once, car was fine for 150 miles, he got in the car and it would move a little bit and then stall, it would then start up, I could move a bit and it would stall again. Got him out of the car and it was fine. Pressed the passenger footwell down and it stalled again. Took the ECU cover off and it ran fine, moved all teh cabled around a bit, put it back together and its been fine since. So if you know how to it may be worth taking off teh ECU cover in the passenger footwell and trying again. JB Quote Link to comment Share on other sites More sharing options...
Shaun. Posted March 25, 2006 Share Posted March 25, 2006 These aren't the best quality and can be a little flaky. I reckon I'll solder mine and heat shrink nice and neat. I crimpted AND solderd mine with RL suggested connectors for the best of both worlds, soldered for sure and plug/socket just in case Need to check my system over fully as not played with it yet, it seemed to be stalling the engine completly when I adjust it up on the digi adjuster towards the off. Hopefully needs properly calibrating or something otherwise might be faulty unit ? Shaun. Quote Link to comment Share on other sites More sharing options...
Steve Posted March 25, 2006 Share Posted March 25, 2006 I crimpted AND solderd mine with RL suggested connectors for the best of both worlds, soldered for sure and plug/socket just in case Need to check my system over fully as not played with it yet, it seemed to be stalling the engine completly when I adjust it up on the digi adjuster towards the off. Hopefully needs properly calibrating or something otherwise might be faulty unit ? Shaun. Sounds like you need the dat file sorting out. PM Terminator, he will sort you out. Quote Link to comment Share on other sites More sharing options...
Shaun. Posted March 25, 2006 Share Posted March 25, 2006 I downloaded and loaded up a dat from Lucifer's Tech support page so it should be ok. I think I will check that it's in there though Steve to be 100 % sure. Shaun. Quote Link to comment Share on other sites More sharing options...
RedM Posted March 25, 2006 Author Share Posted March 25, 2006 RLTC INSTALL might be the key here. Theres very limited space around the ECU and it has been seen on a number of cars that things get all squashed up in there and the ECU starts getting bad signals. I had a similar thing when I drove out to pick up my brother once, car was fine for 150 miles, he got in the car and it would move a little bit and then stall, it would then start up, I could move a bit and it would stall again. Got him out of the car and it was fine. Pressed the passenger footwell down and it stalled again. Took the ECU cover off and it ran fine, moved all teh cabled around a bit, put it back together and its been fine since. So if you know how to it may be worth taking off teh ECU cover in the passenger footwell and trying again. JB Did you find that the car wouldn't start too or did it just keep cutting out? Quote Link to comment Share on other sites More sharing options...
stt Posted March 26, 2006 Share Posted March 26, 2006 He sprayed someting into the air intake which caused the car to start but it wouldn't stay started. QUOTE] I suspect it was a bit of EZI-start,That would indicate to me fueling is down somehow,If you take the cover off under the spare wheel then it should make the noise of the fuel pump more obvious,Should prime itself for a few seconds then stop,Also check the fuel pump relay,There is a remote posibilty that it might of had the voltage by-pass in which case that would be hidden under the trim panel on the left hand side of the boot Quote Link to comment Share on other sites More sharing options...
Branners Posted March 26, 2006 Share Posted March 26, 2006 Did you find that the car wouldn't start too or did it just keep cutting out? car would run fine until my brother pushed down in to the footwell then it cut out straight away. But if your ECU cover has squashed the cables then its possible it just wont start. JB Quote Link to comment Share on other sites More sharing options...
RedM Posted March 26, 2006 Author Share Posted March 26, 2006 ** CAR NOW WORKING ** see HERE Thank you to everyone for your advice and concern. It was much appreciated while I was at panic stations. Gotta love this forum. Quote Link to comment Share on other sites More sharing options...
