Help needed please!!!!!!!
steve single
Just been out in mt tt on way back home the car started spluttering and coughing and juddering on the m way. When i pulled off the m way i tried accellerating a bit but the car just would not move. Basicly it limped home. It felt like it was over heating but theres plenty of water in it and oil! Any sujestions please am worried. Just had racelogic fitted but i turned it totally off and it made no difference.:( :( :( :(
Check for error codes!. did the triangle light come on. Middle of rev counter The sameone that come on when you pull the handbrake
PS what do you meanwhen you said "it felt like it was over heating"?
I'm blonde - how do you check for error codes?
Yeah its well strange. Just by resetting the ecu all you worries and problems go away, hope i could get a possitive reason tho its scary how you pride and joy can just lift it`s legs up and f**K you i am going nowhere!!! then be fixed in ten seconds flat:search:
