Quick qu on door cards pls!!!
nickyboy
Anyone who's removed door cards...
I've taken off all the screws and fixings. When the instructions say you just lift the door card off, how hard am I lifting?!! Do I need to remove the bit at the bottom of the window/top of the door card or will that just come off with the door card?
Don't want to break anything!!!! But it doesn't just "lift off" from the top even though the rest of the card is loose now.
Thanks,
Nick
OK, done that way!!! Much easier!!!
Speaker refitting is going to require a bit more work than I thought as Matt H's effort has fallen to pieces.
How do I disconnect the electric windows power lead? It also doesn't seem to come off so easily!
Turned out there was no clip - just required pulling out!
Last two questions!!
1. Does the airbag light really get affected by the doorcard? ie If I can't be bothered to put the doorcard back on until I get speaker brackets sorted out will that cause a prob?
2. Does anyone still have any speaker brackets for sale?!
Nick
