wkdtime Posted March 22, 2006 Share Posted March 22, 2006 In front of the curtains everyone recomends that singles are the way to go, i.e less things to go wrong, lower EGT's than hybrids...etc. But behind the curatins i have heard a few members mention that quite a few people are not happy with there singles, claiming boost problems, mapping/fueling problems etc and would not recomend it and rather you go with hybrids or big twins for more reliable power. Not putting down the singles or hybrids just want to know your thoughts on this as i will be going down the single route possibly, im personally looking to achieve a true 500BHP road car that is reliable and will not have to be at the tuners every fortnight getting mapped and remapped. your thoughts on this gents and ladies. Quote Link to comment Share on other sites More sharing options...
supradibbs Posted March 22, 2006 Share Posted March 22, 2006 all i would say is single turbos are fecking great!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! only thing i will say in all seriousness is get a budget but allways have a little extra as it can get expensive when mapping setup etc,have a chat with turbofit great guys have some very good packages and some good sound advise good luck mate Quote Link to comment Share on other sites More sharing options...
RedM Posted March 22, 2006 Share Posted March 22, 2006 Are they really worth it for the money though? How often do you give full reign to a single? I'm lucky to get turbo two any action on my daily drive to and from work. A single would be an utter waste IMO. Not even sure BPU justifies the outlay. Quote Link to comment Share on other sites More sharing options...
Branners Posted March 22, 2006 Share Posted March 22, 2006 I would also say that you need to be careful just how far you go with it. The more the car is modified the more complex it becomes and the harder it becomes to track down the problems. My t-61 with a SAFC worked fine, Im now trying to move to a Emanage Blue and its causing problems, not problems that cant be resolved but something that will take a while to resolve. JB Quote Link to comment Share on other sites More sharing options...
Guest Flat4_ire Posted March 22, 2006 Share Posted March 22, 2006 depends how much money,time,patience uve got! Quote Link to comment Share on other sites More sharing options...
SimonB Posted March 22, 2006 Share Posted March 22, 2006 Well there's no difference between a single and big twins when it comes to mapping or fuelling, because the big twins will run in parallel so have the same sort of boost curve as a single. The only difference is that big twins will involve more pipework and expense. As for hybrids, that was the route that I was going to go down, but there's not a lot of point. You can get the stock turbos to perform as well as hybrids provided you sort the fueling etc out which you would have to do for hybrids anyway. The only real point of going hybrid would be if your stock turbos blew and you couldn't afford or didn't want to go single. Basically you want to stick with stockers up to 450bhp. If you like the sequential operation (as I do) then that's what you're limited to. If you want more then go for a single and accept the fact you're going to have to do some work to get it running perfectly. I'm expecting mine to be at full boost after the first turbo normally would have spooled but before the 2nd would. So you lose a bit low down then gain from 3K or so upwards. Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted March 22, 2006 Share Posted March 22, 2006 Really depends if its done properly, with decent equipment. They can be awesome, they can be awful. You must make educated long term choices. Quote Link to comment Share on other sites More sharing options...
wkdtime Posted March 22, 2006 Author Share Posted March 22, 2006 Terry if i were aiming for let say 500-550BHP at crank, what would you recomend as a wise and efficient set up, i.e tubo and all supporting mods. Quote Link to comment Share on other sites More sharing options...
Ray Posted March 22, 2006 Share Posted March 22, 2006 Most people i have chatted to say "regardless of what anyone says be prepared to spend £5000 ATLEAST. To have a decent reliable setup" Quote Link to comment Share on other sites More sharing options...
Guest Flat4_ire Posted March 22, 2006 Share Posted March 22, 2006 Terry if i were aiming for let say 500-550BHP at crank, what would you recomend as a wise and efficient set up, i.e tubo and all supporting mods. t61 kit, 550cc injectors min, SAFC etc etc, Quote Link to comment Share on other sites More sharing options...
Ray Posted March 22, 2006 Share Posted March 22, 2006 t61 kit, 550cc injectors min, SAFC etc etc, No need for an aftermarket ecu then? Im sure thats recommended thou. Quote Link to comment Share on other sites More sharing options...
Guest Flat4_ire Posted March 22, 2006 Share Posted March 22, 2006 No need for an aftermarket ecu then? Im sure thats recommended thou. well emanage is reccomended, but u can go for piggyback setup if ya want, all depends on the monies, 4k to 6k ud wanna be aiming for anyway Quote Link to comment Share on other sites More sharing options...
terribleturner Posted March 22, 2006 Share Posted March 22, 2006 No need for an aftermarket ecu then? Im sure thats recommended thou. Not neccassary at this stage i understand. Maybe slap in some direct fit 650 injectors and an EManage if you can afford the bit more. Quote Link to comment Share on other sites More sharing options...
terribleturner Posted March 22, 2006 Share Posted March 22, 2006 well emanage is reccomended, but u can go for piggyback setup if ya want, all depends on the monies, 4k to 6k ud wanna be aiming for anyway EManage IS a piggyback. Quote Link to comment Share on other sites More sharing options...
Jake Posted March 22, 2006 Share Posted March 22, 2006 EManage IS a piggyback. LOL He doesn't even know how old he is. Quote Link to comment Share on other sites More sharing options...
Guest Flat4_ire Posted March 22, 2006 Share Posted March 22, 2006 errr, an eManage is a piggy back ecu SOREEEE I MEANT TO SAY STANDALONE! Quote Link to comment Share on other sites More sharing options...
JohnA Posted March 22, 2006 Share Posted March 22, 2006 http://www.max-boost.co.uk/stuff/runslikeapig.jpg ................speaking of piggyback Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted March 22, 2006 Share Posted March 22, 2006 Terry if i were aiming for let say 500-550BHP at crank, what would you recomend as a wise and efficient set up, i.e tubo and all supporting mods. Cor that is a tough question. There are various ways to achieve that TBH mate. it depends on a number of things, fuel, compression, management. Dave ( secondjump) has probably the best rounded street setup on the budget side of things IMHO. Stock compression, BL61P, Boostlogic Full tubular set up kit, 650's and an emanage tuned by Ian C. It works extremely well. Quote Link to comment Share on other sites More sharing options...
black cat Posted March 22, 2006 Share Posted March 22, 2006 iam waiting for mine to blow, then it ill be ......errrrrrr loo the turbos gone iam gona have to get it fixed. ill only get one though it should work fine:D Quote Link to comment Share on other sites More sharing options...
jazz1 Posted March 22, 2006 Share Posted March 22, 2006 thats the thing with me my cars only done 15k miles its been parked for 5 years and hardly driven, im mad as i want everything perfect and im willing to spend money for the single. But my dad who gave me the car keeps moaning, not on the fact im spending every penny on the car, but me touching the engine as he says its hardly been driven and your gona fuck up the engine by sticking all sorts of shit(modifying the engine). On the other hand my brother said rip the shit out of (my hardly unsued) the stock turbos and when they blow, go single, but fo the mean time upgrade certain parts like injectors, fuel pump etc im CONFUSED:search: Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted March 22, 2006 Share Posted March 22, 2006 thats the thing with me my cars only done 15k miles its been parked for 5 years and hardly driven, im mad as i want everything perfect and im willing to spend money for the single. But my dad who gave me the car keeps moaning, not on the fact im spending every penny on the car, but me touching the engine as he says its hardly been driven and your gona fuck up the engine by sticking all sorts of shit(modifying the engine). On the other hand my brother said rip the shit out of (my hardly unsued) the stock turbos and when they blow, go single, but fo the mean time upgrade certain parts like injectors, fuel pump etc im CONFUSED:search: come and try mine. Quote Link to comment Share on other sites More sharing options...
Dragonball Posted March 22, 2006 Share Posted March 22, 2006 In front of the curtains everyone recomends that singles are the way to go, i.e less things to go wrong, lower EGT's than hybrids...etc. But behind the curatins i have heard a few members mention that quite a few people are not happy with there singles, claiming boost problems, mapping/fueling problems etc and would not recomend it and rather you go with hybrids or big twins for more reliable power. . It would take a brave man to admit they have cocked up trying to do it 'on the cheap' Quote Link to comment Share on other sites More sharing options...
wkdtime Posted March 22, 2006 Author Share Posted March 22, 2006 so throw some figures at me guys, reliable set up for around 500-550BHP, im assuming 650cc, emanage, Complete single kit.... Quote Link to comment Share on other sites More sharing options...
jazz1 Posted March 22, 2006 Share Posted March 22, 2006 9k for a full complete everything i think:search: Quote Link to comment Share on other sites More sharing options...
wkdtime Posted March 22, 2006 Author Share Posted March 22, 2006 9k for a full complete everything i think:search: mmm That for 2 single kits? Quote Link to comment Share on other sites More sharing options...
