VVTI or Not VVTI?
Kent Phil
Originally posted by Thorin
No :(
I've tried looking into them but there's bugger all information about it out there in the interweb.
I do know that TDi have fitted at least a couple of them to VVTI supe's. Shame Nathan doesn't post any more.
I spoke to Nathan about HKS Valcon. He said the customers who had had the work done were very happy with the result and he recomended it to me aswell.
HTH
HTH
Don't take this the wrong way, but he would say that!! ;)
Nick,
I have a question for you! Is there a way to disable the Traction control/slip control unit on a VVTi? Like in our cars we just pull the fuse under the hood and its done. But according to a guy who has a VVTi he says by pulling the fuse it disables the ABS aswell! Is there a way around this?:)
Guest Terry S
Originally posted by Nic
Terry, I spoke to the owner of the Greddy dealer tonight and he said that the e-manage can be fitted to the VVTi Supra and that the e-manage can be set up to work with the MAF sensor. He told me they had already fitted them to a couple of cars here.
cheers
Thanks Nic that is a great help:thumbs:
Looks like the E-Manage may be the way to go for the modifying VVTi guys then. For those of you that haven't seen it yet it is a piggyback which vastlyexpands on the S-AFC principal. You get 16x16 fuel load sites, and if you buy a seperate cable 16x16 ignition timing sites. Alterations can be made either by a lap top or you can buy a seperate e-01 boost controller that has a small screen with a remote, that when plugged into the e-manage allows alterations.
I believe Thor are going to be offering supply/install/tuned packages on this in the near future.
BTW, they work on the non VVTi Supras too. There is a US forum support the Supras with e-manage already.
I quote:
"Additional features that are built into the system, but are only accessible though the use of our PC-Windows based "e-Manage Support Tool" communication software (Please see our Authorized GReddy Support Dealers for more information) are a 16x16 Airflow Adjustmemt Map, Larger Main Injector correction adjustment, Upgrade Air Flow Meter adjustment, Boost Limiter Cut, Anti-engine Stall, VTEC-fuel adjustment, Real-time Map Trace, Real-time Display, Real-time Communication, and basic Data-logging. "
Is this software available to the end user? If not it's not much good..... Latest Motec software will run VVti cam timing, no worries.
Originally posted by Chris Wilson
I quote:
Yep, you have to buy it though, it's $119 on that site in the USA, or they do bundles with the various harnesses etc:-
E-manage + Support Tool + ignition & injector Harness = $452* (Save $28!)
Looks like they do bundles with the Profec boost controller too, which you can use to change some of the settings. Don't really know anything about this stuff, but it looks like a decent half way house between the SAFC and proper ECUs.
Originally posted by Adam W
I've got a copy of the software Chris, email me if you want it. AFAIK it's a fully functional version, obviously there is some stuff that you can't do without hooking it up to an E-manage though.
Yes please, would be very intrested to see that. Will it e-mail, bearing in mind i only have a slowish ISDN line, so anything over 10 megs is a bit impractical? If it is smallish please send to:
[email protected]
Thanks.
