Darren Posted November 7, 2003 Share Posted November 7, 2003 Originally posted by Thorin No I've tried looking into them but there's bugger all information about it out there in the interweb. I do know that TDi have fitted at least a couple of them to VVTI supe's. Shame Nathan doesn't post any more. I spoke to Nathan about HKS Valcon. He said the customers who had had the work done were very happy with the result and he recomended it to me aswell. HTH Quote Link to comment Share on other sites More sharing options...
Nick Posted November 7, 2003 Share Posted November 7, 2003 Originally posted by Darren I spoke to Nathan about HKS Valcon. He said the customers who had had the work done were very happy with the result and he recomended it to me aswell. HTH Don't take this the wrong way, but he would say that!! Quote Link to comment Share on other sites More sharing options...
Darren Posted November 7, 2003 Share Posted November 7, 2003 Originally posted by Nick Don't take this the wrong way, but he would say that!! I was waiting for that!!!! Quote Link to comment Share on other sites More sharing options...
randy Posted November 7, 2003 Share Posted November 7, 2003 Nick, I have a question for you! Is there a way to disable the Traction control/slip control unit on a VVTi? Like in our cars we just pull the fuse under the hood and its done. But according to a guy who has a VVTi he says by pulling the fuse it disables the ABS aswell! Is there a way around this? Quote Link to comment Share on other sites More sharing options...
Nick Posted November 8, 2003 Share Posted November 8, 2003 Randy - I don't know, haven't tried it as I always switch off the TC when I start the car - force of habbit.... Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted November 10, 2003 Share Posted November 10, 2003 Originally posted by Nic Terry, I spoke to the owner of the Greddy dealer tonight and he said that the e-manage can be fitted to the VVTi Supra and that the e-manage can be set up to work with the MAF sensor. He told me they had already fitted them to a couple of cars here. cheers Thanks Nic that is a great help:thumbs: Looks like the E-Manage may be the way to go for the modifying VVTi guys then. For those of you that haven't seen it yet it is a piggyback which vastlyexpands on the S-AFC principal. You get 16x16 fuel load sites, and if you buy a seperate cable 16x16 ignition timing sites. Alterations can be made either by a lap top or you can buy a seperate e-01 boost controller that has a small screen with a remote, that when plugged into the e-manage allows alterations. I believe Thor are going to be offering supply/install/tuned packages on this in the near future. BTW, they work on the non VVTi Supras too. There is a US forum support the Supras with e-manage already. Quote Link to comment Share on other sites More sharing options...
Nic Posted November 10, 2003 Share Posted November 10, 2003 For more info go to: http://greddy.com/products/electronics_frame.htm I can recommend the e-manage, had mine fitted a year ago and set up on a dyno, made 430bhp at 1.25bar on stock turbos (TTC.) cheers Quote Link to comment Share on other sites More sharing options...
Nic Posted November 10, 2003 Share Posted November 10, 2003 More info here, use babelfish (http://world.altavista.com/) to translate: http://www.trust-power.com/e-man/index.html Quote Link to comment Share on other sites More sharing options...
Nic Posted November 10, 2003 Share Posted November 10, 2003 Terry, Powerhouse Racings new MAP ECU also looks as though it will work with a MAF sensor, there is info about it at http://www.mvpmotorsports.com Quote Link to comment Share on other sites More sharing options...
SimonB Posted November 10, 2003 Share Posted November 10, 2003 More info on the Emanage here: http://www.mohdparts.com/emanage/ Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 10, 2003 Share Posted November 10, 2003 I quote: "Additional features that are built into the system, but are only accessible though the use of our PC-Windows based "e-Manage Support Tool" communication software (Please see our Authorized GReddy Support Dealers for more information) are a 16x16 Airflow Adjustmemt Map, Larger Main Injector correction adjustment, Upgrade Air Flow Meter adjustment, Boost Limiter Cut, Anti-engine Stall, VTEC-fuel adjustment, Real-time Map Trace, Real-time Display, Real-time Communication, and basic Data-logging. " Is this software available to the end user? If not it's not much good..... Latest Motec software will run VVti cam timing, no worries. Quote Link to comment Share on other sites More sharing options...
SimonB Posted November 10, 2003 Share Posted November 10, 2003 Originally posted by Chris Wilson I quote: "Additional features that are built into the system, but are only accessible though the use of our PC-Windows based "e-Manage Support Tool" communication software (Please see our Authorized GReddy Support Dealers for more information) are a 16x16 Airflow Adjustmemt Map, Larger Main Injector correction adjustment, Upgrade Air Flow Meter adjustment, Boost Limiter Cut, Anti-engine Stall, VTEC-fuel adjustment, Real-time Map Trace, Real-time Display, Real-time Communication, and basic Data-logging. " Is this software available to the end user? If not it's not much good..... Latest Motec software will run VVti cam timing, no worries. Yep, you have to buy it though, it's $119 on that site in the USA, or they do bundles with the various harnesses etc:- E-manage + Support Tool + ignition & injector Harness = $452* (Save $28!) Looks like they do bundles with the Profec boost controller too, which you can use to change some of the settings. Don't really know anything about this stuff, but it looks like a decent half way house between the SAFC and proper ECUs. Quote Link to comment Share on other sites More sharing options...
Adam W Posted November 11, 2003 Share Posted November 11, 2003 I've got a copy of the software Chris, email me if you want it. AFAIK it's a fully functional version, obviously there is some stuff that you can't do without hooking it up to an E-manage though. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 11, 2003 Share Posted November 11, 2003 Originally posted by Adam W I've got a copy of the software Chris, email me if you want it. AFAIK it's a fully functional version, obviously there is some stuff that you can't do without hooking it up to an E-manage though. Yes please, would be very intrested to see that. Will it e-mail, bearing in mind i only have a slowish ISDN line, so anything over 10 megs is a bit impractical? If it is smallish please send to: [email protected] Thanks. Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted November 11, 2003 Share Posted November 11, 2003 Chris, you may also wish to take a look at the e-manage thread in the tech section. Quote Link to comment Share on other sites More sharing options...
Ian C Posted November 11, 2003 Share Posted November 11, 2003 I'd be interested to know what you thought of the E-Manage Chris -Ian Quote Link to comment Share on other sites More sharing options...
