Angarak Posted March 21, 2006 Share Posted March 21, 2006 Hi guys, I think one of my rear wheel bearings are on the way out so I jacked up the rear to check them. There is no play in either wheel (top/bottom or side/side). On my previous car (FWD Corolla gti) I was able to spin the rear wheels forward to see if the noise appeared when there was no obvious play in the wheel when jacked up. I've noticed on my Supra that I cannot spin the wheels forward freely, is this due to my car having LSD?....or should I be able to spin the rear wheels freely when its jacked up. Before you ask, yes I did have it in neutral and the handbrake was off. I can turn the wheels forward using some force, but they wont freely spin. Cheers Quote Link to comment Share on other sites More sharing options...
Syed Shah Posted March 21, 2006 Share Posted March 21, 2006 Sticky caliper. Quote Link to comment Share on other sites More sharing options...
Mcgoo Posted March 21, 2006 Share Posted March 21, 2006 They should spin fine. try removing your pads and gently pushing your piston in, sometimes this is enough to free them. Quote Link to comment Share on other sites More sharing options...
D8MOA Posted March 21, 2006 Share Posted March 21, 2006 even non LSD'd have drag when trying to turn the wheel Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 21, 2006 Share Posted March 21, 2006 :amen:Sticky caliper. Quote Link to comment Share on other sites More sharing options...
Angarak Posted March 21, 2006 Author Share Posted March 21, 2006 Cheers Guys, I'll take a look at the caliper Quote Link to comment Share on other sites More sharing options...
Nic Posted March 22, 2006 Share Posted March 22, 2006 I have a brand new rear wheel bearing here at a good price if you need one. Quote Link to comment Share on other sites More sharing options...
Angarak Posted March 22, 2006 Author Share Posted March 22, 2006 I'll let you know Nic...hoping to get time to check it out later Quote Link to comment Share on other sites More sharing options...
Soop Dogg Posted March 24, 2006 Share Posted March 24, 2006 This can also happen if your handbrake is adjusted so that you only have a couple of clicks movement on it AND you've jacked the car up on the body. (So that the rear suspension is fully extended.) The handbrake cable is stretched slightly in reaching the hubs as they hang lower. This has the effect of pulling the handbrake on ever so slightly. If you place the car on axle stands under the lower wishbones, the suspension will be in its normal position, with the rear wheels up inside the arches. Then try spinning the wheels. If they spin freely then there's nothing wrong with your calipers. Quote Link to comment Share on other sites More sharing options...
