DannoSupra Posted March 20, 2006 Share Posted March 20, 2006 Anyone here got an Apex'i AVC-R? If so, where is it mounted? Cheers Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted March 20, 2006 Author Share Posted March 20, 2006 i'll put it in my glove Quote Link to comment Share on other sites More sharing options...
Robert Posted March 20, 2006 Share Posted March 20, 2006 will you be able to see it ok there tho? i had mine mounted in front of where the clock used to be Quote Link to comment Share on other sites More sharing options...
CJ Posted March 20, 2006 Share Posted March 20, 2006 I mounted mine above the dash against the window on the right hand side corner. Quote Link to comment Share on other sites More sharing options...
michael Posted March 20, 2006 Share Posted March 20, 2006 Mine is in the glovebox at the moment but it's going into the roof when I find someone to retrim my headliner to take it and the SAFC. I used to have it mounted on a Nokia phone bracker next to the dash, worked OK there but passengers used to knock it. Quote Link to comment Share on other sites More sharing options...
Class One Posted March 20, 2006 Share Posted March 20, 2006 Michael, is that bits of nuclear fallout in your dash pic?? Quote Link to comment Share on other sites More sharing options...
Nic Posted March 20, 2006 Share Posted March 20, 2006 Best install of the AVCR I remember seeing (I think ) was Justin Foden's, he had his mounted in the headlining behind the light, if memory serves me right. This is going back quite a few years, so not sure if pics are still on the forum. Quote Link to comment Share on other sites More sharing options...
Class One Posted March 20, 2006 Share Posted March 20, 2006 Hasn't Supradibbs got his mounted there as well? See here Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted March 20, 2006 Author Share Posted March 20, 2006 This is where mine is... What does the SAFC do? is it worth getting? Quote Link to comment Share on other sites More sharing options...
michael Posted March 20, 2006 Share Posted March 20, 2006 Michael, is that bits of nuclear fallout in your dash pic?? You've lost me.... Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted March 20, 2006 Author Share Posted March 20, 2006 How hard is it to remove the Pass Air bag? Glove out and a couple of bolts under there yeah? im sure i could use the pass airbag cover to do something Quote Link to comment Share on other sites More sharing options...
michael Posted March 20, 2006 Share Posted March 20, 2006 im sure i could use the pass airbag cover to do something I'm using mine to hopefully save someone's life Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted March 20, 2006 Author Share Posted March 20, 2006 I'm using mine to hopefully save someone's life hmmmm..... true Quote Link to comment Share on other sites More sharing options...
Nic Posted March 21, 2006 Share Posted March 21, 2006 How hard is it to remove the Pass Air bag? Glove out and a couple of bolts under there yeah? im sure i could use the pass airbag cover to do something Very quick and easy if you follow these simple instructions Instructions for Removing Passenger Side Airbag 1. Stick 2 bits of sellotape over your steering wheel airbag in a criss-cross pattern (the reason for this will become clear later). 2. Find a sturdy odject of relative mass to your Supra. 3. Drive at said object, at a speed of approx. 5mph until impact occurs. 4. Check to see if pass airbag has been removed, if not repeat steps 1 to 3, but increase speed by 5mph. Repaeat until airbag successfully removed. WARNING: Remove sellotape from the steering wheels at arms length Quote Link to comment Share on other sites More sharing options...
Nic Posted March 21, 2006 Share Posted March 21, 2006 How hard is it to remove the Pass Air bag? Glove out and a couple of bolts under there yeah? im sure i could use the pass airbag cover to do something Seriously, if you do remove it, just make sure you disconnect the battery first, it should then be a simple task of removing screws and disconnecting the wires. Quote Link to comment Share on other sites More sharing options...
Ian R Posted March 21, 2006 Share Posted March 21, 2006 I mounted mine above the dash against the window on the right hand side corner. Me too Quote Link to comment Share on other sites More sharing options...
