RedM Posted March 20, 2006 Share Posted March 20, 2006 What is the maximum length for a serial cable? I need to connect the pc to my RLTC, don't have a laptop and the car is down on the drive. I cannpt move the PC and reckon the shortest distance to be about 6-10 meters. Can I use a cable that long without losing data? Quote Link to comment Share on other sites More sharing options...
DamanC Posted March 20, 2006 Share Posted March 20, 2006 Shouldnt be a problem fella, however finding a cable that long for a resonable price will be your main problem. hth Quote Link to comment Share on other sites More sharing options...
milocoon Posted March 20, 2006 Share Posted March 20, 2006 You could remove it from the car (metal CPU box) with cable B (has the led and serial plug on that loom:blink: ) and power it with 12 V in the house by using pin 2 for +ve and pins 1 and 14 for negative. What do you need to change as the Digital Adjuster can change quite a few things. I`ve not needed a laptop at all Quote Link to comment Share on other sites More sharing options...
michael Posted March 20, 2006 Share Posted March 20, 2006 Most people reckon 15m is about the most to go for to keep things working OK. I could flog you a laptop if you like Quote Link to comment Share on other sites More sharing options...
RedM Posted March 20, 2006 Author Share Posted March 20, 2006 You could remove it from the car (metal CPU box) with cable B (has the led and serial plug on that loom:blink: ) and power it with 12 V in the house by using pin 2 for +ve and pins 1 and 14 for negative. What do you need to change as the Digital Adjuster can change quite a few things. I`ve not needed a laptop at all I don't have the digital adjuster version. I need to input the wheel sizes although Mike Broadbent of Racelogic replied to my question on the RL Yahoo group and seem to imply that the wheel size values don't matter as long as the speed of each is roughly the same! Ho hum. Quote Link to comment Share on other sites More sharing options...
RedM Posted March 20, 2006 Author Share Posted March 20, 2006 I could flog you a laptop if you like How much? Quote Link to comment Share on other sites More sharing options...
michael Posted March 20, 2006 Share Posted March 20, 2006 How much? I have a selection available - £30 > £150+ price range depending on spec / reliability / battery life Quote Link to comment Share on other sites More sharing options...
edd_t Posted March 20, 2006 Share Posted March 20, 2006 why not get a serial to USB converter cable, can go even longer then Quote Link to comment Share on other sites More sharing options...
Boomer Posted March 21, 2006 Share Posted March 21, 2006 I seem to remember that the RS-232 serial spec allowed for 50 foot of cable at 19200 baud. Decreasing the speed to 2400 baud would allow something like 3000ft but it may cost more to buy a 3000ft cable than one of the laptops.... More details here Quote Link to comment Share on other sites More sharing options...
