letmeshowyou Posted March 20, 2006 Share Posted March 20, 2006 have you considered that built bottom end that Lucifer has tho? Sounded pretty good to me! Quote Link to comment Share on other sites More sharing options...
terribleturner Posted March 20, 2006 Author Share Posted March 20, 2006 Yeah i did but Sam and Greg are only up the road and they have just done Ian R's sup too. Plus i may ever be allowed to come up and do my single instillation while the engine is still out the car Plus over £5K for the full spec one is a little more than i really wanted to pay for now Quote Link to comment Share on other sites More sharing options...
letmeshowyou Posted March 20, 2006 Share Posted March 20, 2006 fair play. that sounds like a result in a way in that case good luck! Quote Link to comment Share on other sites More sharing options...
bignum Posted March 20, 2006 Share Posted March 20, 2006 sorry to here about this my friend, you say your temps where high like 130degrees/c, was this oil temp if so how did it go that high , are you using good quality oil and lastly what mileage are you up too, good luck anyway. Quote Link to comment Share on other sites More sharing options...
Kopite Posted March 20, 2006 Share Posted March 20, 2006 Sorry to hear this dude, i'm scared of my single going on and the engine giving up straight away Nightmare, Hopefully it's not as ££ as you think Quote Link to comment Share on other sites More sharing options...
terribleturner Posted March 20, 2006 Author Share Posted March 20, 2006 sorry to here about this my friend, you say your temps where high like 130degrees/c, was this oil temp if so how did it go that high , are you using good quality oil and lastly what mileage are you up too, good luck anyway. Yeah good oil in there and im about 89600 odd miles (60K KM). I usually only ever see 110 tops (Oil temps that is). and if i ever go above it's only by 5 degrees most. It's the 2nd time i've had the temps rise to this level and the first was because my water pump went Like a phoenix she will rise again, better and stronger and ready for everything im gonna throw at it Quote Link to comment Share on other sites More sharing options...
Digsy Posted March 20, 2006 Share Posted March 20, 2006 Well, from anaysing the video I can say Ian was 100% spotty-cock-on. The knocks come at the rate of one every two engine revs (about 16 per second at 2000RPM). Unfortunately, it doesn't look like that lead was as hopeful as first thought Quote Link to comment Share on other sites More sharing options...
chilli Posted March 20, 2006 Share Posted March 20, 2006 probably one clank for the compression stroke and one for the power stroke then... Quote Link to comment Share on other sites More sharing options...
Digsy Posted March 20, 2006 Share Posted March 20, 2006 probably one clank for the compression stroke and one for the power stroke then... Nope, just one for each power stroke on the affected rod. Quote Link to comment Share on other sites More sharing options...
chilli Posted March 20, 2006 Share Posted March 20, 2006 1 rod, 4 strokes, that would be rpm over 4 not over 2? Quote Link to comment Share on other sites More sharing options...
b_have Posted March 20, 2006 Share Posted March 20, 2006 Or two rods? Quote Link to comment Share on other sites More sharing options...
chilli Posted March 20, 2006 Share Posted March 20, 2006 unlikely, but possible if it were caused by oil starvation. 1 is more likely though isn't it? Quote Link to comment Share on other sites More sharing options...
Jake Posted March 20, 2006 Share Posted March 20, 2006 1 rod, 4 strokes, that would be rpm over 4 not over 2?but the four strokes are carried out over two revolutions. Quote Link to comment Share on other sites More sharing options...
chilli Posted March 20, 2006 Share Posted March 20, 2006 ahhh, doh! of course lol, being dumb, I'll get me coat... So most likely a single big end dead. Quote Link to comment Share on other sites More sharing options...
JohnA Posted March 21, 2006 Share Posted March 21, 2006 Revolutions or evolutions, if it's damage due to oil starvation then there are a lot of other places that should be checked for critical damage. Bad case scenario. It *does* sound bad, but let's hope for the best... Quote Link to comment Share on other sites More sharing options...
chilli Posted March 21, 2006 Share Posted March 21, 2006 yep of course, there is always a chance it is something else much less costly to put right lets hope that is the case Quote Link to comment Share on other sites More sharing options...
terribleturner Posted March 21, 2006 Author Share Posted March 21, 2006 Well it'll be on it's way up to Turbofit soon for further investigation. I'll post up the results when i know. Quote Link to comment Share on other sites More sharing options...
Kopite Posted March 21, 2006 Share Posted March 21, 2006 Good luck Quote Link to comment Share on other sites More sharing options...
Ian R Posted March 21, 2006 Share Posted March 21, 2006 Well it'll be on it's way up to Turbofit soon for further investigation. I'll post up the results when i know. Your in safe hands there matey Quote Link to comment Share on other sites More sharing options...
chilli Posted March 21, 2006 Share Posted March 21, 2006 good luck, hope it can be fixed quickly and cheaply Quote Link to comment Share on other sites More sharing options...
Guest 87toysupratt Posted March 22, 2006 Share Posted March 22, 2006 rod knock for sure, been there. easy way to see is to drain your oil and check for metalic sparkles. And if you're sure you had sufficient oil in there as stated above resolve the issue. If its hard to turn over then you spun a bearing and you'll need to turn the crank for sure or get a new one. If you do the work yourself its wont cost too much to repair depending on if anything else went wrong in the engine. Quote Link to comment Share on other sites More sharing options...
