Help, Internet Problems
DannoSupra
If it finds any critical objects - my advice is to quarantine them all, then you should be fairly safe. Don't be too shocked if you do find a lot.
I run IE with no major problems, (touch wood) just remember to install all the critical safety updates, and check periodically for Malware, using Ad-Aware or similar in the same way you would run your virus checker.
However as Jake says - Internet Explorer is a target for most of the vulnerabilities etc. Firefox is an alternative browser which comes highly recommended.
Mike
Just keep up to date with anti spyware/adware programs, run them regularly and you should be ok :) You can also install an anti popup blocker like the one that comes with the google bar.
Or as Jake suggests Firefox but thats a whole other browser :)
