Terminator Posted October 30, 2003 Share Posted October 30, 2003 That would be my first action if I had the same problem. It will then take a few miles for the ECU to adjust again. It would probably sort itself out anyway, but this should speed it up. EFI fuses, it show where they are on the lid. If that does not fix it, you should see if you have engine fault codes stored. Link to comment Share on other sites More sharing options...
Paul Posted October 30, 2003 Author Share Posted October 30, 2003 Originally posted by Terminator If that does not fix it, you should see if you have engine fault codes stored. [/b] where would they be then, stored in the boot? I'll try the EFI fuses then give ya a shout Paul Link to comment Share on other sites More sharing options...
dude Posted October 30, 2003 Share Posted October 30, 2003 Originally posted by Roy err - what are fuses ? what do they look like ? where can i find them ? help phil !!!! Youd soon find them if they were edible !!!!!!!!!!!!!!!!!!!! Dude:flame Dev Link to comment Share on other sites More sharing options...
Roy Posted October 30, 2003 Share Posted October 30, 2003 piss off john - i'm trying to watch bullitt to avoid thinking of my diet! Link to comment Share on other sites More sharing options...
Paul Posted October 30, 2003 Author Share Posted October 30, 2003 Dude, Maybe it's my UK scoop, as it actually does something then maybe it's letting in the cold Unlike the wannabes....... jigsaw bonnet and slap on to look like UK jobbies? Possible? Paul Link to comment Share on other sites More sharing options...
dude Posted October 30, 2003 Share Posted October 30, 2003 No dude your car just starts like it does everything else .....................................................SLOWLY Joke ive got thios prob. too got an idea (after talking to Leon) will report back soon Dude:flame Dev Link to comment Share on other sites More sharing options...
Paul Posted October 30, 2003 Author Share Posted October 30, 2003 Cheers mate, let us know what he says as it seems to be common. I love J specs really Paul Link to comment Share on other sites More sharing options...
Aerotop Dave Posted October 31, 2003 Share Posted October 31, 2003 Originally posted by Timwildman does an injection car have a choke? So what's the answer then, technical bods? Link to comment Share on other sites More sharing options...
Paul Posted October 31, 2003 Author Share Posted October 31, 2003 Today I left it for 5hrs and when I started I made a point of turning on, leaving for 10/15 secs then turned over with little/no accelerator. This worked a treat, maybe it needs a little more help when cold? Pau; Link to comment Share on other sites More sharing options...
Ian C Posted October 31, 2003 Share Posted October 31, 2003 Maybe your fuel system isn't priming itself properly when you switch off, or maybe you have an injector not quite closing and leaking the fuel pressure out? Sounds like it's trying to start with no fuel in the lines between tank and fuel rail - takes a few seconds to repressurise from this condition. Turning on the ignition and waiting will also prime the fuel system, which may explain your success when doing this. -Ian Link to comment Share on other sites More sharing options...
Paul Posted October 31, 2003 Author Share Posted October 31, 2003 Thanks Ian, that sounds reasonable. So when you turn off it should shut down leaving fuel still up where it's needed for the re-start? I guess it's not a massive problem if the method I used earlier works. Just wait a few seconds for it to prime with fuel then start. Paul Link to comment Share on other sites More sharing options...
dude Posted October 31, 2003 Share Posted October 31, 2003 I'll try this tommorrow if it works i'll wire in a glow plug light off a diesal and patent the idea. Dude:stupid: Link to comment Share on other sites More sharing options...
Paul Posted October 31, 2003 Author Share Posted October 31, 2003 Can you knock up a fibre glass starting handle too so I can glue it to the front It'll go great with me UK 'horns' Paul Link to comment Share on other sites More sharing options...
dude Posted October 31, 2003 Share Posted October 31, 2003 Havent got enough f.glass to make one 'to scale' dude:flame Dev Link to comment Share on other sites More sharing options...
Paul Posted October 31, 2003 Author Share Posted October 31, 2003 Originally posted by dude Havent got enough f.glass to make one 'to scale' What, you've used all your supply up making them bonnet scoops for J-specs Paul Link to comment Share on other sites More sharing options...
dandan Posted November 1, 2003 Share Posted November 1, 2003 I think between all of us we're talking about a few different problems: 1. Starting after leaving for less than a few hours - hot starting 2. Starting after leaving for up to a day or overnight 3. Starting after not driving the car for a long period of time eg a week or so All three may well be similar problems such related to a lack of fuel in the rail, which may be due to evaporation or injector not closing as ian suggested. Mine is as case no.3 as it always starts perfectly when driven more often than once a week. I only ever get a problem when cars been left standing for a long time. I doubt this could be either of the above reasons as evaporation or injector symptom would cause a problem in daily starting-but it doesn't. Strange eh? Maybe it's ignition related? Link to comment Share on other sites More sharing options...
Aerotop Dave Posted November 3, 2003 Share Posted November 3, 2003 Or it could be the auto choke. If someone actually answered the question of if the Supra has one or not! Link to comment Share on other sites More sharing options...
nicksupra67 Posted November 3, 2003 Share Posted November 3, 2003 not so much an auto choke!! but a temp sensor which increases ur revs when cold :flame Dev Link to comment Share on other sites More sharing options...
