is the fan shroud on a NA the same as a TT.
SupraStar 3000
another problem is, you can really make a custom fan shroud as it mihgt hit the fan, although it depends on how much it is hitting on the bonnet, say a few mm would be ok to make a custom shroud but if the shroud is 5cm too high then there wont be much you can do.
D'ya mean THIS bit of shroud ?
the large round bit actually covering the fan blades ??
believe that's same on both ??
no reason why that bit would be different, or do you mean the metal shield
by the horn further forward, STILL think that bits the same too ??
Are you sure that the bonnet hits the shroud mate?When i fitted my TSII it would not close properly,it turned out that the bonnet latch was not "deep" enough so i had to file about 1.5mm off the latch for it to lock over the bonnet lock bars
Got 2 bad pics to show what i mean,pic 1 showes your latch and pic 2 is where to file the 1.5mm.
Hope this help and that your bonnet will fit mate.I looks the biz when fitten :)
yes mate, I'm sure.
see pics. (show marks where mesh has scratched black trim)
First, the loops didn't locate into the clasp which was about 15mm out.
I decided to radically change the hoop as it needed major ajustments to fit so I made to longer hoops as show in the pic.
The hood now closes but hits the fan plastic.
The clasps are adjusted to highst position but i didn't think of fileing them down. i may try this later.
Thanks for the info guys :)
