Clarification Before Buying Clamps/Hose
terribleturner
Im pretty sure im right but just need someone to second me before i start buying.
When buying clamps i use the diameter of the pipe to find the right one?? So like below it's 98mm, so i'd be after say a clamp that's measurements are AROUND that size (94mm-102mm)??
The circumference doesn't come into play at all.
Sound right??
Yeah, but don't forget that hoses are normally sized by internal diameter whereas clamps are sold on the min and max size they will clamp which is the outside diameter of the hose they are going on. So you need to add some on for the thickness of the hose. That's caught me out before.
OK these Mikalor clamps are bugging me. The pipe is 80mm, so add 5mm for the hose on top, but what size clamp do i buy?? 79-85mm or the 85-91mm?? Does the 85-91 tighten up alot more than 85?? Should i go for the 91-97mm clamp instead?? Just worried they are gonna be too loose.
where abouts on the car are you talking about. how many at this size do you need. ive got some bags of these laying around somewhere. ive used 80>85mm successfully coming off the throttle body into the IC hardpipe
