Daston Posted March 16, 2006 Share Posted March 16, 2006 Hi guys Is it safe to remove the exhaust manifold's heat shield and leave it off? The reason I ask is I am getting a vibration at 6k rpm but not all the time and I am thinking it may be the problem. Quote Link to comment Share on other sites More sharing options...
black cat Posted March 16, 2006 Share Posted March 16, 2006 how often do you rev to 6000rpm??? Quote Link to comment Share on other sites More sharing options...
Daston Posted March 16, 2006 Author Share Posted March 16, 2006 not often but that is when it is at its worse it starts comming in around 4.5-5 Quote Link to comment Share on other sites More sharing options...
Daston Posted March 16, 2006 Author Share Posted March 16, 2006 so is it safe to take off??? Quote Link to comment Share on other sites More sharing options...
Digsy Posted March 16, 2006 Share Posted March 16, 2006 I'd say no. If it was ok for it not to be there then Toyota wouldn't have installed it in the first place. Quote Link to comment Share on other sites More sharing options...
Daston Posted March 16, 2006 Author Share Posted March 16, 2006 lol that is true but I was going to a quick blast up the dual carrage way (5min form my house) just to see if the knocking goes Quote Link to comment Share on other sites More sharing options...
Digsy Posted March 16, 2006 Share Posted March 16, 2006 If it's a one off for a test just check that any nearby wires or plastic parts are tie wrapped out of the way. Quote Link to comment Share on other sites More sharing options...
Daston Posted March 16, 2006 Author Share Posted March 16, 2006 ok will do Quote Link to comment Share on other sites More sharing options...
Big Supes Posted September 1, 2014 Share Posted September 1, 2014 Bump.. Just in the process of replacing the turbo link pipes and life would a lot easier if I could lose this completely. One of the mounting points has corroded away also which is causing vibrations. Quote Link to comment Share on other sites More sharing options...
