Captain Posted October 27, 2003 Share Posted October 27, 2003 I know theortically it's a fairly simple task, but im gonna change the oil on the Supra this w/e. As there's no such thing as a '5 minute job' I was wondering if there are any pearls of wisdom you guys may possess which could help me.... like recommending an oil, or a make of filter etc. Cheers Paul Link to comment Share on other sites More sharing options...
Gordon F Posted October 27, 2003 Share Posted October 27, 2003 Valvoline 5/50 oil and stock Toyota filter, tho' some do recommend a larger Lexus one. Link to comment Share on other sites More sharing options...
Scooter Posted October 27, 2003 Share Posted October 27, 2003 If you have a TT, access is tight. I've heard of people moving the Power steering reservoir to get access from the top, or removing the engine undertray and getting at it from underneath (this i spose is dependant on whether you have decent access). The filter will spill a fair amount of oil (probably seems alot more than it actually is, but certainly enough to make a mess) as you unscrew it the last few turns, so maybe rig up a bag into which the excess will run and into which you can let the filter drop, or at least something to channel the excess away to a drain tray. just hope your filter isn't done up as tight as mine was. Link to comment Share on other sites More sharing options...
SimonB Posted October 27, 2003 Share Posted October 27, 2003 Yep, filter is a sod. I prefer the above method. Take the battery out, unbolt the power steering reservoir and hope you have four foot long bendy arms... Plastic bag method is definitely advisable as Scooter says. Link to comment Share on other sites More sharing options...
Kevin Huntley Posted October 28, 2003 Share Posted October 28, 2003 Originally posted by Chilli Boy like recommending an oil, or a make of filter etc. Cheers Paul We have the highly recomended Valvoline 5w 50 in stock along with TRD Filters. US or Jap spec(better filtration) Hope that helps Check out the service parts section on the website. Thanks Kevin http://www.envyperformance.com Link to comment Share on other sites More sharing options...
Captain Posted October 28, 2003 Author Share Posted October 28, 2003 Thanks chaps, looks like i'll give Kevin a call in the morning. Cheers, Paul Link to comment Share on other sites More sharing options...
