Dash lights spedo ect.
MizTheWiz
Hi guys just a quick question. its time to change some lights behind my speedo. so thought while im there ill change the lot. Quesion is anyone know how many there are in/behind the cluster, are they the same behind the heating buttons ect. and do these (see pic below) do the job....... ????
There are several different types (at least 6, maybe more) Some have bulb holders which take standard capless bulbs, some are 1 piece jobbies that are only available from toyota. There are also some LEDs in the heater control unit.
behind the speed, rpm and temp/fuel gauge they re 3 bulbs. factory its 3W but i have put 5W Phillips hyper white (blue when no powered). Like that you got nice hyper white gauges. Those bulbs are the same as you have in the headlight
