Guest Twincharge Posted October 27, 2003 Share Posted October 27, 2003 Hi Guys Im new on here and looking for someone who is currently using the HKS Twin-Power DLI ignition amplifier. Is anyone here? Nad Quote Link to comment Share on other sites More sharing options...
Wez Posted October 28, 2003 Share Posted October 28, 2003 Yep, only really neccesary with big mods and high boost or with an AEM when you want to run over a 1 BAR of boost. Quote Link to comment Share on other sites More sharing options...
Guest Twincharge Posted October 28, 2003 Share Posted October 28, 2003 Thanks for replying Oh....ok I admit Im not a Supra owner, but at least it is Toyota! I just knew someone here would be using it. Im running a HKS Twincharge setup in my Corolla GTi-16 (Supercharger & Turbo) and put in the HKS Twin-Power DLI a few months ago. I then started to experience some ignition problems that seems intermittent. At some points the car just stalled and refused to start, it really made the car undrivable. After eliminating every ignition component and all wiring, I eventually turned to the Twin-Power, unplugged and the problem went away! Plugged it back in and the problem re-surfaced! Now Im not sure if it has become faulty or not, or if I have even installed it correctly. I know that the Supra ignitor is very similiar to my own (4AGZE), in fact some guys use it on their 4AGZE. Could you tell me if your red LED on the Twin-Power module is solidly lite or if it is supposed to flash with the ignition? Any chance you could tell me what wires you tapped into for the yellow wires coming from the Twin-Power? Quote Link to comment Share on other sites More sharing options...
Adam W Posted October 28, 2003 Share Posted October 28, 2003 I've read that it makes the ignition coil(s) work a lot harder and can lead to quick coil failures on higher mileage engines. Might be worth looking into. Quote Link to comment Share on other sites More sharing options...
Wez Posted October 28, 2003 Share Posted October 28, 2003 The LED flashes in time with ignition although sometimes does appear solid. Did you use the nasty wire tap clips that came with it or did you solder? Goto http://www.horsepowerfreaks.com and look under ignition, there are some independant instructions which I used and I have had no issues so far. Quote Link to comment Share on other sites More sharing options...
Guest Twincharge Posted October 30, 2003 Share Posted October 30, 2003 Thanks Guys I appreciate the help, could you tell me how many coil packs the Supra actually has? I take it that it uses 6 coil packs? Quote Link to comment Share on other sites More sharing options...
Wez Posted October 30, 2003 Share Posted October 30, 2003 Originally posted by Twincharge Thanks Guys I appreciate the help, could you tell me how many coil packs the Supra actually has? I take it that it uses 6 coil packs? Correct, 6 coils Quote Link to comment Share on other sites More sharing options...
Batmax Posted October 31, 2007 Share Posted October 31, 2007 These Hks Dli or the Hks Dli twin power works in single turbo supra? Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted October 31, 2007 Share Posted October 31, 2007 Blew the dust of that bugger didnt you Quote Link to comment Share on other sites More sharing options...
Wez Posted October 31, 2007 Share Posted October 31, 2007 Blimey They will work in any supra, question is, do you NEED it. Quote Link to comment Share on other sites More sharing options...
Batmax Posted November 10, 2007 Share Posted November 10, 2007 any link to see how hard or easy the install ? Quote Link to comment Share on other sites More sharing options...
Wez Posted November 10, 2007 Share Posted November 10, 2007 http://www.racecarnewmedia.co.uk/hks/pdf/twinpower/Twin%20power%20dli%20type.pdf Quote Link to comment Share on other sites More sharing options...
suprafan72 Posted November 10, 2007 Share Posted November 10, 2007 How is your map on your car.. Could be incorrect dwell settings that could of screwed your DLI? Quote Link to comment Share on other sites More sharing options...
