Setting up a network
TLicense
OK,
I've got two computers. 1 PC running winxp pro, 1 laptop running win2000 pro.
Both connect wirelessly to the internet via a netgear router, by a wireless pci card and wireless pcmcia card respectively.
Now I want to be able to look at the files on my pc via my laptop and vice versa, maybe some printing too would be nice.
What I've done so far is select a folder on my pc that I want to share and selected share this folder. However I still can't see it on my laptop.
Obviously I'm doing something wrong. Can someone give me a step by step procedure of how I go about setting up my network.
Cheers guys!
first of all try in the run box off of start \\[computername]\c$
try it on either machine and see if u can get a folder up :)
OK now bear with me....
I typed in \\[laptop]\c$ and got an error message telling me the network path wasn't found.
I tried it on my laptop and it asked me for a network password.
I typed in my login and my password but it didn't accept it.
i had this problem when 1 pc was win2000 so i made it XP and now i dont have the problem.
Is the laptop called laptop, (can be found by doing right click on my computer choosing properties, under Tab network identification will tell you PC name) if so should read
\\laptop\c$
Start>run then type cmd and press return... you should get a dos box. Now type IPCONFIG and press return. Should return, amongst other things, an IP address. Now go to the other machine and browse to \\IPADDRESS\c$
When I type that a dos window opens, and instantly closes.
I think I have the IP address'. Not sure.
My netgear gatway is 192.168.0.1
I think my pc is 192.168.0.2 and my laptop 192.168.0.5
Does that sound about right?
If so I get the same results as above. :search:
OK so I typed that in on both and got the following:-
PC
Connection-specific DNS suffix:
IP Address:192.16.0.2
Subnet mask:255.255.255.0
Default Gateway:192.168.0.1
laptop
IP Address:192.16.0.5
So when I type the IP address in the other computer, it says:-
ie on my laptop:-
Firefox can't find the file at ///192.168.0.2/c$.
(I browse using firefox, shouldn't be a problem should it?)
I just tried it the other way (Laptop to PC) and got the following:-
pinging 192.168.0.2 with 32 bytes of data:
Reply from 192.168.0.2: bytes=32 time=3ms TTL=128
Reply from 192.168.0.2: bytes=32 time=1ms TTL=128
Ping statistics for 192.168.0.2
Packets: sent =4, received = 4, lost = 0 (0% loss)
Approximate round trip times in milli-seconds:
minimum = 1ms, maximum = 3ms, average = 1ms
Are you sure you're pinging the correct IP address. You've mentioned both 192.168.0.5 and 192.16.0.5. The first one is more 'standard'.
Also, if you're trying to browse one machine from the other using 'My Network Places', the chances are it's not working because you may have to enable NetBIOS over TCP/IP first. (It works differently if you simply try to map a network drive or access it from the command line, as described already.)
When you go to "Browse the Network" / "My Network Places", you are using the browser service. Unfortunately, the browser service uses NetBIOS over TCP/IP.
So, you need to check NetBIOS over TCP/IP is enabled. Bring up your Network Connections. Open the "Local Area Connection" that you are having trouble with... (not the one connected to the Internet). Open Properties. Double click on "Internet Protocol (TCP/IP)" in the list. Under the General tab, click Advanced. Click on the WINS tab and then check the box "Enable NetBIOS over TCP/IP". That's it.
While you're at it, check the Computer Browser service is running. Go Start -> Control Panel -> Administrative Tools -> Services. Make sure the "Computer Browser" service is started and set to Automatic.
With any luck, this will allow you to browse machines in the Workgroup and should also resolve your file sharing problems.
Also, what firewalls are you running? It might be a good idea to disable them just while you're trying to diagnose the problem. Note: I'm not advocating turning firewalls off for more than a few minutes!!
Looks like the ping is okay. So probably an authentication problem.
Are both machines in the same workgroup ?
Mike
They weren't. I've just run the network ID wizard on both so they are both part of the "workgroup" workgroup. (The PC was on a workgroup called "home")
Now I can still see my laptop from my pc, but when I type in the IP of my pc on my laptop it now says "the connection has timed out"
However I can still ping the IP address.
Wa-hay! Got it working. Not sure how, but now I can see both ways. Even on explorer which is what I wanted to do! Cheers guys! ;) :)
One last question. How do I change from just seeing the IP address to seeing the actual names of the computers? (My girlfriend will be using this and she's even more computer clue-less than me!)
