afennell Posted March 11, 2006 Share Posted March 11, 2006 Hi, just having a few problems removing the rear discs. The callipers are all off, so should the discs just come off with some gentle tapping? Or do you need to release the handbrake shoes? sorry if this sounds dim. thanks Link to comment Share on other sites More sharing options...
RobSheffield Posted March 11, 2006 Share Posted March 11, 2006 releasing handbrake shoes can help, back them off with the adjuster. but you will need most likely to use two bolts in the threaded holes on the mounting surface of the disc. iirc they are M8 or M10 thread. Link to comment Share on other sites More sharing options...
afennell Posted March 11, 2006 Author Share Posted March 11, 2006 Showed it the club hammer! Link to comment Share on other sites More sharing options...
merckx Posted March 11, 2006 Share Posted March 11, 2006 Definately wind back the handbrake, if you force them off you may damage the handbrake mechanism. The lip that has been created in the drum can make them difficult to remove. Link to comment Share on other sites More sharing options...
mawby Posted March 11, 2006 Share Posted March 11, 2006 Showed it the club hammer!Oh no! I did that on one of mine and bent some spring-holdy-thingy on the hand break. When I had put everything back on there was a constant metallic 'clink' on every rotation. Had to take it all apart and replace the bent bit. Was not impressed but learnt my lesson. Link to comment Share on other sites More sharing options...
merckx Posted March 11, 2006 Share Posted March 11, 2006 I bent one of the levers when I did the van, I've learnt my lesson too! Link to comment Share on other sites More sharing options...
