JohnK Posted March 12, 2006 Share Posted March 12, 2006 Maybe they are hours of a Creation day. If you can build a universe in 6 days, maybe a supra matrix can be swapped in 4 hours. Yea, i'm aware its a massive job, I just wonder what would happen if you asked a garage that gets its times from autodata to do it. Link to comment Share on other sites More sharing options...
JohnA Posted March 12, 2006 Share Posted March 12, 2006 They'll most probably call you and give you the bad news, and if you demand that they stick to their original estimate they can always put things back together (perhaps hastily) and ask you to take the car somewhere else. If you get threatening because you're not in the mood to pay double, they could accidentally damage some cables back there in the process (go figure who did what later on) I'd steer clear of clueless garages (who should have known better in the first place) or those who charge you a couple hundred quid to do the job. You pay peanuts, you get monkeys - human nature. Link to comment Share on other sites More sharing options...
Terminator Posted March 12, 2006 Share Posted March 12, 2006 If you go to Toyota you'd be lucky to get change from a grand. My suspicion would be that anyone who knows what they're doing will quote too high to deter you from having it done at their place. I had an old scorpio that had a slight leak, I got really stupid quotes like £800 6 years ago. Some places just said no wont touch it. It is a bastard of a job the whole dash has to come out. I had to do thjis on one of my son's cars it took two of us all day to take the old matrix out and fit the new one and stick it all together. Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted March 12, 2006 Share Posted March 12, 2006 i've tackled some major jobs before, i'll try anything once im not offering though (saving this one for when it goes on me) Link to comment Share on other sites More sharing options...
Scooter Posted March 12, 2006 Share Posted March 12, 2006 Could you not use something like this http://www.kalimex.co.uk/section.html?secpath=01.03.&pgid=3 I know its not recommended to use these sealers in the cooling system but you could just flush the matrix itself as i think it has x2 rubber hoses in and out of the bulkhead. So flush the coolant out of the matrix, follow the instructions for the above product, in which it recommends draining all the fluid from the area (this is possible by just blowing through one of the tubes) and leaving over night. Now this means none of the sealer goes in the block, rad water pump etc and only leaves the very small chance of bits breaking off later, but this i'd say is unlikely given that after leaving over night to set you can flush through again with a hose pipe. A few bits of hose, a bit of time and as long as you are patient no risks to the rest of the cooling system...........i'd say that has to be worth a go, no? Link to comment Share on other sites More sharing options...
JohnA Posted March 13, 2006 Share Posted March 13, 2006 I would never-ever use this sort of 'liquid' fixes in the cooling system of a car I intent to use in the future. Especially if it is a performance car that might overheat in the summer and warp the head (or worse) Link to comment Share on other sites More sharing options...
