Rear Hub
RobSheffield
this is kinda for anyone who has removed the rear hub and/or bearing assembly themselves.
I recently carried out this task and had Toyota replace a bearing sourced from Steve Manley.
having refitted it all back to the car, i have now discovered that the almost inaudible thrumming noise has turned out to be the drive flange very slightly loose in its mounting. i have tightened the centre bolt as much as possible, but still, it is slightly loose.
pictures to follow unless someone can suggest a reason that i had not thought of :)
  • 1 year later...
