RobSheffield Posted March 10, 2006 Share Posted March 10, 2006 this is kinda for anyone who has removed the rear hub and/or bearing assembly themselves. I recently carried out this task and had Toyota replace a bearing sourced from Steve Manley. having refitted it all back to the car, i have now discovered that the almost inaudible thrumming noise has turned out to be the drive flange very slightly loose in its mounting. i have tightened the centre bolt as much as possible, but still, it is slightly loose. pictures to follow unless someone can suggest a reason that i had not thought of Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted March 10, 2006 Author Share Posted March 10, 2006 anyone with any ideas at all it seems that the drive shaft is not quite secure within the drive flange. im not sure why though, its mostly removed from the car, but i cant see any reason for it being so insecure to be quite honest its f***ing me off right now Quote Link to comment Share on other sites More sharing options...
4packet Posted December 3, 2007 Share Posted December 3, 2007 Hi Rob, sorry to drag up this old thread. Did you get to the bottom of this issue in the end? I would be interested to know the outcome. Cheers Martin Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted December 3, 2007 Author Share Posted December 3, 2007 It would appear that Toyota removed the bearing they fitted initially and refitted it, which is a bit of a no-no Removed it all to find the bearing was totally and utterly shot Another new bearing fitted by someone that knew what they were doing and it was all ok. Quote Link to comment Share on other sites More sharing options...
4packet Posted December 3, 2007 Share Posted December 3, 2007 That was clever of them! Good ol' dealer network. Its not a 5min/1spanner job either to extract that bearing..... Thanks for the reply Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted December 3, 2007 Author Share Posted December 3, 2007 Absolutely not, but after having done a few its not a 1 day job either Quote Link to comment Share on other sites More sharing options...
bignum Posted December 3, 2007 Share Posted December 3, 2007 If you drive on a worn bearing the drive flange wears aswell so you need to replace both really, and possibly the drive shaft due to fretting. Quote Link to comment Share on other sites More sharing options...
