How To: Refurbish coil pack connectors
Guest phatGZ
Hi Guys sorry to bring this back but wondering if this connector (part no 90980-11246) is the same for vvti supras?
Only need 3 of them as for some reason toyota decided on a wasted spark system
Thanks
  • 2 months later...
  • Replies 51
Posted Images
I'm confused, why is it soldering time if new connectors are needed? I looked and mine and it seems the wires just slip into the back of the housing?
I'm sure when you get new female pins you get a short length of wire pre attached so you cut the old one off then solder the new one on.
There's 2 things you can replace, 1 the outer plastic housing, that obviously doesn't require any soldering and is what Ian describes above.
But after a while the metal clips inside the housing get beyond their best, so if you order new ones of those you get the female ends with a short length of wire on them, to attach them you need to cut off the old female end (once you've removed it from the plastic housing) and solder the new one on.
The process Ian describes above is the plastic housing replace only, you retain you existing metal female pins
EDIT Sorry Matt, I just reread Ians original post, I have no idea why "it's soldering time", maybe Ian can explain :)
Edited by jevansio (see edit history)
Cheers, Jevansio. At least that's cleared up my question, if not what Ian actually means! :D
  • 2 weeks later...
  • 3 months later...
  • 8 months later...
  • 9 months later...
  • 7 months later...
  • 2 months later...
  • 4 months later...
  • 4 years later...
