Anyone able to supply these in the UK?
Ark
And how would one compress a carbon hose onto the hard fittings? I think you are a bit off track here, somewhere. The stock rubber hose is fine if rotated correectly before the clips are tightened or released.
Er Chris, these come with rubber joins to the hard fittings. Just like the bling bling stainless steel versions.
How thick is the carbon pipe, just asking because you need to make sure you have a good seal and it could be easy to overtighten the clamp and crack the carbon pipe if it's thin. This is a new one on me, I've not heard of carbon fibre being used to carry fluids before, must be getting old.
F 1 carbon fibre gearboxes?:taped:
