DBR Posted March 6, 2006 Share Posted March 6, 2006 Before, the seals were replaced - my gearbox was very clunky and the shifting gear wasn't smooth ... because of the leak. Now, with the seals replaced and the gearbox no longer leaking oil - gearshift selection & change is very smooth. cheers fella, maybe i have a leek somewere an all my luvly v160 is escaping ill check it out Link to comment Share on other sites More sharing options...
Alex Posted March 6, 2006 Share Posted March 6, 2006 is the esso oil mentioned earlier the same as the v160 oil???? Nobody's tried it so nobody knows....but as Getrag say it's ok it probably is. Hijack The Toyota T-IV for the auto comes in large amounts so it might seem expensive but I think you can get 2 changes out of 1 tub. Link to comment Share on other sites More sharing options...
dan4 Posted March 7, 2006 Share Posted March 7, 2006 done a little research.... the d21065 oil is used by both peugeot and rover and seems to be dextron 2 (i stand to be corrected on that). The dealership i work in includes both rover and citroen(still in the PSA group so i can access peugoet) this means that i may be able to help with the gathering of this oil for some of you in kent if you have the same problem with toyota that i do Oh and thank you toyota for refusing to accept that v160 oil is to be used and does exist Link to comment Share on other sites More sharing options...
dan4 Posted March 7, 2006 Share Posted March 7, 2006 got the correct stuff.... and it comes in 2 litre bottles.... where theres a will theres a way.... :) Link to comment Share on other sites More sharing options...
dan4 Posted March 7, 2006 Share Posted March 7, 2006 heres the spec i have from the bottle..... ZF TE-ML 09 Link to comment Share on other sites More sharing options...
CJ Posted March 7, 2006 Author Share Posted March 7, 2006 got the correct stuff.... and it comes in 2 litre bottles.... where theres a will theres a way.... :) Do you mean V160 - cos that is the correct stuff. Link to comment Share on other sites More sharing options...
CJ Posted March 7, 2006 Author Share Posted March 7, 2006 Oh and thank you toyota for refusing to accept that v160 oil is to be used and does exist You need to call Steve Manley. No hassles, no dramas and a great service. Link to comment Share on other sites More sharing options...
dan4 Posted March 7, 2006 Share Posted March 7, 2006 Do you mean V160 - cos that is the correct stuff. no i meant the esso d21065 (also the correct stuff) Link to comment Share on other sites More sharing options...
