V0oD0o Posted October 16, 2003 Share Posted October 16, 2003 Hi all, Driving to work this morning, my engine light came on. I pulled over, switched off and left it for a few moments and when I started it up again, the light was off. It came on again about 5 minutes later. This happened about 3 times and then stopped happening for the rest of my journet to work. Nothing seemed untoward with the car, it was running at the normal temperature and everything seemed OK. It's just been picked up for a service, so I'm hoping that will sort the problem, but I don't know. Any advice? Thanks guys, Mike Link to comment Share on other sites More sharing options...
JamesG Posted October 16, 2003 Share Posted October 16, 2003 Check for any other lights on the dashboard that may indicate what the problem is. Otherwise an ECU diagnostic code may have been registered. It's easy to read it by following these instructions: http://mkiv.supras.org.nz/techo.htm#ENGINE_CODES James. Link to comment Share on other sites More sharing options...
V0oD0o Posted October 16, 2003 Author Share Posted October 16, 2003 Thanks mate! Mike Link to comment Share on other sites More sharing options...
