mr keef Posted March 1, 2006 Share Posted March 1, 2006 Ello! after fitting the frontmount and now running 1 bar,i'v started getting a kinda misfire when driving on full boost,i was gona bung some NGK's in tommora to see if this sorts it.but what would you guys recommend for bpu?are the NGK plugs (BKR7E, or BCPR7ES) gapped to 0.8 the correct ones?i just wana try NGK's because i know i can get them fast. thankyou:) Quote Link to comment Share on other sites More sharing options...
Lucifer Posted March 1, 2006 Share Posted March 1, 2006 No YUK! IX Irridium's if you must use the NGK's. Quote Link to comment Share on other sites More sharing options...
mr keef Posted March 1, 2006 Author Share Posted March 1, 2006 So its NGK - Iridium - BKR6EIX or BKR7EIX with the gap left alone? as per the alex spark plug fao? Quote Link to comment Share on other sites More sharing options...
Lucifer Posted March 1, 2006 Share Posted March 1, 2006 So its NGK - Iridium - BKR6EIX or BKR7EIX with the gap left alone? as per the alex spark plug fao? Yes BPU I usually gap to 0.0028 Quote Link to comment Share on other sites More sharing options...
merckx Posted March 1, 2006 Share Posted March 1, 2006 NGK BKR7E (6097) work perfectly on a BPU car, gapped at 0.8mm Only about £11 for 6 . Why buy anything more expensive if these work? Quote Link to comment Share on other sites More sharing options...
mr keef Posted March 1, 2006 Author Share Posted March 1, 2006 Thankyou lads! Quote Link to comment Share on other sites More sharing options...
tbourner Posted March 1, 2006 Share Posted March 1, 2006 BCPR7ES will be better if your coil packs are tired though. I gapped mine to 0.75mm I think. Quote Link to comment Share on other sites More sharing options...
carl0s Posted March 1, 2006 Share Posted March 1, 2006 NGK BKR7E (6097) work perfectly on a BPU car, gapped at 0.8mm Only about £11 for 6 . Why buy anything more expensive if these work? Yup that's what I use. BKR7E-VX Quote Link to comment Share on other sites More sharing options...
mr keef Posted March 1, 2006 Author Share Posted March 1, 2006 Yup that's what I use. BKR7E-VX Whats the VX mate? also whats with the numbers people put after the main BKR7E some people say BKR7E-6097? Quote Link to comment Share on other sites More sharing options...
carl0s Posted March 1, 2006 Share Posted March 1, 2006 6097 is a specific like model number, so in theory is all you need to go and buy them. The VX means fine-tipped platinum I think. Quote Link to comment Share on other sites More sharing options...
carl0s Posted March 2, 2006 Share Posted March 2, 2006 The BKR7EVX come ready to drop in on the BPU car. (I think.. that's what I've been doing for the last couple of years anyway!) Quote Link to comment Share on other sites More sharing options...
Ian C Posted March 2, 2006 Share Posted March 2, 2006 I'd stick to NGKs to start with, they are good and they are cheap, a rare thing in this universe Get platty's or even better iridiums once you are sure the fuelling is right and it doesn't have any det. They last a lot longer, can't say anything else about them that makes them 'better' than NGKS though. -Ian Quote Link to comment Share on other sites More sharing options...
Alex Posted March 2, 2006 Share Posted March 2, 2006 No YUK! IX Irridium's if you must use the NGK's. WTF??? There is NOTHING wrong with using the BKR7E's on BPU. My T61 was very happy on them too... There is no need to use iridium's unless you're desperate not to change plugs that often....and the coppers are a damned site cheaper. I've done a huge FAQ on spark plugs HERE which is a bit more informative than "No Yuk". FWIW, I personally wouldn't use Platinum's on anything over stock. Quote Link to comment Share on other sites More sharing options...
mr keef Posted March 2, 2006 Author Share Posted March 2, 2006 WTF??? There is NOTHING wrong with using the BKR7E's on BPU. My T61 was very happy on them too... There is no need to use iridium's unless you're desperate not to change plugs that often....and the coppers are a damned site cheaper. I've done a huge FAQ on spark plugs HERE which is a bit more informative than "No Yuk". FWIW, I personally wouldn't use Platinum's on anything over stock. Yea seen the write up ya done Alex its excellent!! Quote Link to comment Share on other sites More sharing options...
JohnA Posted March 2, 2006 Share Posted March 2, 2006 Aye, NGK all the way. No scare stories of their iridiums losing the tips either. (that I know of) As for the plug gaps, it depends on the quality of combustion under boost. I run stock gaps and have never had a misfire even at silly boost. Others need to close the gaps from 1 bar upwards. Quote Link to comment Share on other sites More sharing options...
mr keef Posted March 2, 2006 Author Share Posted March 2, 2006 I think i'll go with the ngk on a 0.8m seems to be a good starting point Quote Link to comment Share on other sites More sharing options...
Jonny5 Posted March 2, 2006 Share Posted March 2, 2006 Out for a blast last night and anything over about 0.9 bar of boost, a misfire developed from 4.5Krpm onwards.. I too have read the FAQ (thanx Alex) and have concluded it may well be the spark plugs to blame. I've just been out and bought a set of NGK BKR7E - 11 for the cheap sum of £11 squids... Gonna fit them at work today, so I'll let you know if it's cured my misfire.. If not I might be on coil pack duty lol.. cheers Jon Quote Link to comment Share on other sites More sharing options...
Alex Posted March 2, 2006 Share Posted March 2, 2006 The -11 is the gap they are set to out of the factory - 1.1mm - For a TT with mild mods I'd start at 0.9mm and test performance...if you get a missfire try 0.8 etc... Quote Link to comment Share on other sites More sharing options...
Jonny5 Posted March 2, 2006 Share Posted March 2, 2006 Ok will do, thanks for that Alex.. cheers Jon.. Quote Link to comment Share on other sites More sharing options...
Jonny5 Posted March 2, 2006 Share Posted March 2, 2006 well thats that little interruption taken care of. A new set of plugs and my misfire has disappeared so hopefully it will stay like that.. Hope yours get sorted too Mr Keef:eyebrows: cheers Jon.,. Quote Link to comment Share on other sites More sharing options...
Barnstormer Posted March 2, 2006 Share Posted March 2, 2006 Hi, I needed some new plugs and found the cheapest place here.. http://www.mister-solutions.co.uk/ BKR7EIX £6.49 inc vat for 6 inc delivery £40 Not sure if the owner is VAT registered so maybe why so cheap. ATB Quote Link to comment Share on other sites More sharing options...
mr keef Posted March 3, 2006 Author Share Posted March 3, 2006 well thats that little interruption taken care of. A new set of plugs and my misfire has disappeared so hopefully it will stay like that.. Hope yours get sorted too Mr Keef:eyebrows: cheers Jon.,. lol cheers mate gona fit them on saterday! Quote Link to comment Share on other sites More sharing options...
