Defi-Link Cont. Unit
MR.B
Just finished installing some nice Defi BF gauges and the Defi-Link control unit. All seems to work fine apart from the illumination of the control unit.
As soon as the ignition is switched on the unit illuminates how its supposed to then goes out after a few seconds. When I switch the lights on however it illuminates for a split second then goes out - any ideas?
It worked fine when I had all the dash out and tried it. Only thing I can think is that I took the feed for illumination from the cigarette lighter and either the connection has come loose refitting the dash or there is not enough 'juice' getting there to power both? :conf:
Any help much appreciated 'cos its buggin' me now!
I pluged it all in as per instructions, double checked, then taped the control box down, put everything back together :stupid: then found it only worked with the lights on! :twak:
Took it all apart again, checked everything was ok as per instructions which it was, and decided the only thing I could try was the other output.
This time I checked it before I put it all back and it works fine :)
