yellow oil light
addi
I'm almost positive (handbooks downstairs, and TOO cold to
go out to car now :p )
...that, YELLOW is Oil LEVEL... RED is Oil PRESSURE..
ie. YELLOW one will come on when LEVEL is just a bit too low
(OR, if you corner fast, the oil may 'roll' away from the level ?)
the RED is the VERY worrying one ! ! ! ! !
is yer level OK ? ? :conf:
s'possible ! ! !:conf:
as I said, under VERY heavy cornering, it might get a 'falsely' low
reading 'cos of Oil 'sway' ? ? but then, mine never has !
(perhaps mine's broke and don't register at ALL ? :p )
Is yer RED (pressure) light showing before you start-up ?
and, goes out ~fraction of second AFTER start-up ?
THAT's the REAL sign...................
FatS.
The yellow one is 'check your oil level'
And the red one is the 'Stop-the-godda**-car-RIGHT-NOW!' light :)
BTW....my last car (a 91 Celica GTi) had the same yellow/red system. And it was very handy on the 3S-GE engine...wich tend to use a bit of oil...when age first sets in :)
But...ive actually come across this yellow light flicker on/off twice this last month in my Supra too...and the oil-levels are fine...a tad under FULL but...is this sensor of the nervous type or what?
Not that long ago since i had my last oilchange either...using Castrol 0w40 i think....
Anyone?
@lpher
Do yer revs drop slightly BELOW normal idle when you do the
"Heavy-Brake" thing Steve ? ? ?
ie. the Oil Pressure will MOMENTARALY drop below 'normal' and
just flicker the RED... if so that's not too bad.
IF it's flickering with revs at idle or above then EITHER Pressure
is 'genuinely' low (:( ) or the Oil Pressure SWITCH is a bit iffy
(so the pressure is OK but the switch thinks it's a bit low ?)
  • 3 months later...
My oil light came on a month ago so I topped her up.
The light came on again today for 30 seconds and went off so I am worried now. I will check the colour of the light in a minute.
If I am losing oil where is most likely to be leaking from? Checked the sump plug, check the filter for tightness. Where else should I check.
Cheers
J
