Grindy noise from rear brakes
RedM
When I brake I can hear a kind of grindy noise from my rear brakes, like something being dragged.
I've just had new pads and discs all around but, I have to confess, I had the noise before then. I was hoping the new pads etc would sort it.
Also, when I reverse and brake I can hear a clunk but not when going forwards.
Apparently, my handbrake pad things will need replacing within a year. Could they be anything to do with it. I'm assuming they only come into play when parking.
Any ideas
It could be the handbrake shoes or springs have become loose or damaged.
Whilst driving slowly, start lifting the handbrake up slowly and see if the noise differs.
Best to whip off the rear discs and check the shoes/springs and if it is these you will also see scorching inside the disc bell
martine!!! :D
peter was over at my house last night as i had the exact same thing on mine and a heavy grating noise on left handers too, it turned out to be the dust thingy that sits behind the rear disc it had about 1mm clearence, all he done was bend it out slightly and took it for about a 5 mile journey and not a peep
hope this helps too
Just got off the phone with Peter and he believes it's down to the handbrake shoe retainer pins being bent. At the last replacement they were probably not fitted correctly.
Ordered a new kit. Not expensive in the least. See how it goes.
