How much to be de catted
Adam
Double de-cat pipes range from about £230 to £320 (from Envy, Chris Wilson etc). The car won't pass the MOT with both cats out unless you're pals with the tester but they usually come in two bits and it's fairly easy to stick the second cat back in which should be enough to get through it.
Trouble is its quiet difficult to get underneath the engine to fit it every time. Can i get one cat off but leave the other one on purly for the mot tester
You could but you'll not see the boost gain that you would by removing both. Think it's the first cat that's more restrictive so get that one out if you just do the one.
its before 1992 you dont need a cat.
its illegal not to have one,
ive never been sure on the law on imports.
surely if you can still pass exhaust emissions it should be ok, wheres the written law on this.
but with the police doing road side exhaust testing?
hmmmm
