FMIC-Fitting
ADD
Well i had a whole day to do it in on my own and it took a few hours. The bumper was really the biggest pain, but if you look in the repair manual it should point out where abouts all the bolts are. Probably took an hour + to get off and 15 mins to put back. And that was all by myself, and it started pissing down while i was doing it :(
Christ your car is on the piss...can you mount anything straight if it's like that?
Provided you got the full kit which includes the smaller expansion tank and the re-routed PAS cooling lines its a pretty straight-forward job to do. I've removed and refitted it since and it only took a couple of hours in total.
I was charged £280 by Max-GT to fit a Greddy 3-row & FPR, which in retrospect was a rip-off.
:D I can work in all kinds of situations, actually looks alot worse than it is.
i presume i should get all this with the intercooler then!!
well fingers crossed
Take a picture of the kit of list everything you have so someone can double check everthings there. What clamps have you got?? Jubillee standard jobiess??
this may help you out a bit.
Im left my supra into a garage toget the intercooler installed ended up fitting it my self and then the garage had the cheek to charge me £180. for the hire of there garage..........
http://www.mkiv.com/techarticles/greddy_fmic_manual/index.html
it's not too bad!! took me 4 hours, but I did not have a right hand screwdriver
