ArghJae Posted February 19, 2006 Share Posted February 19, 2006 I got a new set of goodyear f1's fitted a couple of weeks ago and woke up to find my r/o/s tyre flat, but only after i had driven in a few hundred metres, it didn't help that i was rushing to work. Well I changed it and then got to work. Later on today I took it to kwik-fit and asked if they could repair it but they said that from looking at the wear on the wall it had been driven on and that the metal plating in the sidewall was damaged so would need a replacement. I'm gonna try pump it up and leave it over night to see if it goes flat again but I'm worried that if I get this sorted I may get a blowout on the motorway or something. Should I just order a new one and swallow the 120 I wasted on the last one? Also, does anyone use that green goo you put into a tyre to stop punctures from occuring? Thanks all in advance. Link to comment Share on other sites More sharing options...
uk-rich Posted February 19, 2006 Share Posted February 19, 2006 get a new one, just not worth the risk mate Link to comment Share on other sites More sharing options...
stt Posted February 19, 2006 Share Posted February 19, 2006 If the tyre is run flat for a duration then the rubber will be peeled off the inside tyre wall and basically renders the tyre knackered,Unfortunatly you will have to swallow the 120 quid again and stump up for a new tyre,Ive been in the situation a few times before and I know it isnt nice Link to comment Share on other sites More sharing options...
SimonB Posted February 19, 2006 Share Posted February 19, 2006 I would go back to the place that you got it from and tell them it went flat - it might be a defective tyre in which case they should send it back to Goodyear and give you a replacement. Worth a try anyway. But if not definitely worth changing it. Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted February 19, 2006 Share Posted February 19, 2006 yep if they think sidewall damaged defiantly change it, If it was just a puncture i would be happy with it repaired. If it was unsafe to drive a puncture repaired tyre then it wouldnt be legal to have it fixed! Link to comment Share on other sites More sharing options...
ArghJae Posted February 19, 2006 Author Share Posted February 19, 2006 I guess I'll just get a new tyre then, it's a right pain as I've been spending loads gettign the car road worthy and I'm still spending when the cash could be used for decent mods on the car. Oh well, I'll just order a new one, thanks. Link to comment Share on other sites More sharing options...
ArghJae Posted February 19, 2006 Author Share Posted February 19, 2006 Link to comment Share on other sites More sharing options...
Dave F Posted February 19, 2006 Share Posted February 19, 2006 Mate same thing just happened to mine. When I checked the pressures a few weeks back the rear left was low so checked it and found a screw in the tread. Took it to kwik fit to see if it was worth repairing and they pointed out the sidewall had softened and bubbled:shock: Replaced it straight away, cant take chances with tyres fella but as said before I think you should go back and ask for a refund/replacement. Link to comment Share on other sites More sharing options...
Ian R Posted February 19, 2006 Share Posted February 19, 2006 I got a new set of goodyear f1's fitted a couple of weeks ago and woke up to find my r/o/s tyre flat, but only after i had driven in a few hundred metres, it didn't help that i was rushing to work. Well I changed it and then got to work. Later on today I took it to kwik-fit and asked if they could repair it but they said that from looking at the wear on the wall it had been driven on and that the metal plating in the sidewall was damaged so would need a replacement. I'm gonna try pump it up and leave it over night to see if it goes flat again but I'm worried that if I get this sorted I may get a blowout on the motorway or something. Should I just order a new one and swallow the 120 I wasted on the last one? Also, does anyone use that green goo you put into a tyre to stop punctures from occuring? Thanks all in advance. Did you buy it from Quikfit if so check your guarantee mate as I think it covers you Link to comment Share on other sites More sharing options...
s crane Posted February 19, 2006 Share Posted February 19, 2006 just changed my back tyres to f1s £300 for two 265/35/18,ran f1s on mr2 turbo ,front one went flat and did side walls Link to comment Share on other sites More sharing options...
Lewis Posted February 19, 2006 Share Posted February 19, 2006 I have had low pressure for a few days (checked this morning and it was 8PSI -FECK) it looked tottally fine, it was only when I could hear it that I worried, is there a way to externally see if there is a problem with the sidewall as it looks fine on first glance Link to comment Share on other sites More sharing options...
Dave F Posted February 19, 2006 Share Posted February 19, 2006 I have had low pressure for a few days (checked this morning and it was 8PSI -FECK) it looked tottally fine, it was only when I could hear it that I worried, is there a way to externally see if there is a problem with the sidewall as it looks fine on first glance Get it pumped up and and push against both sidewalls mine was very soft on the inside but fine on the outside if in doubt get it to somewhere like ATS as they usually check things for free. Link to comment Share on other sites More sharing options...
Lewis Posted February 19, 2006 Share Posted February 19, 2006 cheers bud will do Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted February 19, 2006 Share Posted February 19, 2006 I got a new set of goodyear f1's fitted a couple of weeks ago and woke up to find my r/o/s tyre flat, but only after i had driven in a few hundred metres, it didn't help that i was rushing to work. Well I changed it and then got to work. Later on today I took it to kwik-fit and asked if they could repair it but they said that from looking at the wear on the wall it had been driven on and that the metal plating in the sidewall was damaged so would need a replacement. I'm gonna try pump it up and leave it over night to see if it goes flat again but I'm worried that if I get this sorted I may get a blowout on the motorway or something. Should I just order a new one and swallow the 120 I wasted on the last one? Also, does anyone use that green goo you put into a tyre to stop punctures from occuring? Thanks all in advance. Driving on a flat for a few meters can almost certainly damage the sidewall and a few hundred meters it's guaranteed to be damaged, not worth the risk, as others have said get it replaced. Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted February 19, 2006 Share Posted February 19, 2006 I have had low pressure for a few days (checked this morning and it was 8PSI -FECK) it looked tottally fine, it was only when I could hear it that I worried, is there a way to externally see if there is a problem with the sidewall as it looks fine on first glance You may have a leaking bead. I see a lot of leaks due to corrosion on the rim where the bead seats, get your fitter to throughly clean the rim where the tyre beads and if necessary seal it with bead sealer. Link to comment Share on other sites More sharing options...
ArghJae Posted February 19, 2006 Author Share Posted February 19, 2006 I used some tyreweld on the tyre and got it pumped up, it seems fine for a couple days use whilst I wait for my new tyre from blackcircles. There is bulging from the sides of the tyre so it has to be changed. The problem is that I went to loadsa petrol stations and found 1 can of tyreweld which I used, I wanted to have another one just incase it's flat in the morning and I need a quickfix to get to work. Guess I'll find out in the morning. Funny thing is that someon wrote in the dirt above my drivers door the night before "cock blocker", either someone jealous over my car or jealous over my girl, next night I get the flat. I've just been having so much bad luck in the last fortnight with my car, hope it gets better. Thanks all. Link to comment Share on other sites More sharing options...
