TrickTT Posted February 19, 2006 Share Posted February 19, 2006 I know when changing the brake fluid, its normal to start far away from the master cylinder and work closer ie. n/s/r - o/s/r - n/s/f -o/s/f. Question is, with all lines from the master cylinder going to the abs pump on the n/s wing, should you take this as the start point and bleed in order from furthest away from the abs unit which would make the order o/s/r - n/s/r - o/s/f - n/s/f. Or does it not really make any difference. Link to comment Share on other sites More sharing options...
SEDGE Posted February 19, 2006 Share Posted February 19, 2006 Don't think it makes any difference..just done mine as you first described and it worked fine Link to comment Share on other sites More sharing options...
