Removing discs
Dave F
Being the good man that I am, I said I would fit the oth er halfs Grandmothers discs + pads. It is a 1990 starlet 1.0 with 50,000 genuine miles on it and it seems the discs(originals?) are rusted on and will not budge. there are no grub screws holding them on so its not that. What is the best way of releasing them.
Are there any holes in the disc hub face without bolts in? There are generally two (between the studs) at 180 degrees from each other. They are threaded, to enable you to put the appropriate size bolt in and then turn it in until it puts pressure on the hub, thus separating the disc from the hub....
