Supra Guide and Model Differences Chart
mawby
  • Replies 140
Posted Images
ok cheers
what type of bhp am i looking at if i go for an n/a it might help
richie :cool:
220 or 225, thereabouts. I think you can expect to increase that to 235 tops if you remove the airfilter / replace it with a non-functioning air filter (obviously not something you should do) and decat.
brill i might get myself an n/a then and save myself a few pennys cheers (it is my 1st supra after all)
richie:cool:
  • 1 month later...
n/a are definatly worth getting if you havent had one before, i started off with a n/a auto and i was delighted with the way it drove and how fast it was through gears. now moving onto a tt manuel, so hope im as impressed. i never thought id have an auto. but it doesnt drive like an auto. so reponsive. Getting the experience from the n/a was vital in my experience.
very good guides :)
  • 4 weeks later...
Hi guys! Just a super quick quizzer, am in Japan as I type hunting a clean monocoque for a build - can I just confirm that as far as anyone has heard all of the bare chassis, regardless of trim and spec should be identical - meaning only slight differences between the pre and post facelifters only?
Many thanks!
  • 1 month later...
Guest StratOS
i read through the guides and i never knew Supra have a Tiptronic GB. I never seen 1 in Malaysia so far. Anyone here having the tiptronic model? and I've been finding a Supra with VVT-i and its also very hard here. Supra is a very rare car in Malaysia.
It's the same gearbox as the regular auto, except it has an ugly selector stick, and up/down buttons on the steering wheel, which is why it's called tiptronic. It's the same normal 4spd a340e box.
  • 1 month later...
Guest migligs
Hello All
I recently bought a 1994 Supra TT, having trouble identifying which model it actually is? Gz, Rz etc. seems to have quite a few factory
options such as Targa-top, front leather seats of which drivers is
electric. is an auto has 2jz-Gte on build plate & engine cover. has no reference anywhere in engine bay of model type. I am hoping some Supra guru on this site will be able to shed some light.
I personally believe its a Gz-aerotop as i don't think Rz's come in aerotops? just dont have code to verify this.
Regards
Alfie
Hello All
Regards
Alfie
Definitely a GZ Aero. Same as mine :).
Yes all J-spec 2JZGTE Auto Aerotops are GZ, model code on the VIN plate should be E-JZA80-AJPZZ
Yep, that's the one.
  • 2 weeks later...
  • 3 weeks later...
  • 4 weeks later...
  • 2 months later...
Guest Avve
Great guide! Does anyone know the gross weight of a j-spec TT's? I have a 1994 auto TT (standard roof) and relly need to know this to register the car.
Regards!
Avve/Sweden
Guest Avve
Hi, thanks but what I need is the total, gross weight. My car is a 1994 TT RZ auto with standard roof. The car was never sold here in Sweden and the authorities need an official statement about the cars max allowed weight. I have checked other swedish-reg'd Supras and they all have different curb weights, max weights, some are 2 seaters and other reg'd as 4 seaters...
Avni
  • 2 weeks later...
Hi
the J-spec Supra RZ TT auto 1994 has a gross (=maximum) weight of 1730 kg. Means it's legally only a 2-seater here in Sweden!
  • 1 month later...
  • 3 months later...
  • 4 months later...
  • 2 months later...
