Kitchen nightmare
Supragal
  • Replies 79
I know, I was just messing.
Heres the first wall with it's white coat of paint. Getting there!!!
Wow its looking good. How did you get your plaster to dry so quickly? We had a room done recently and it took about a week to dry!
ps when you said you can fit kitchens do you mean plumbing aswell? We've got one that needs doing but having to move the sink etc.... ;-)
Sounds odd to me... I thought plaster should take no more than 4 hours to go off? Depends how thick it was on the wall and what you mean by "gone off" if you mean completely bone dry then a week could be right, but it's paintable after 4 hours.
Cold damp room would means it takes longer?
Kitchens and water- yes but it depends by how much? If you mean over the other side of the room then it's a nightmare to move the main water feed etc IIRC. You'd have to run the plumbing round the room rather than moving that.
It is a very large room and some of the walls are external (if that makes a difference). What do you mean by 'gone off' don't know these builders terms i'm almost a DIY dunce! I thought it had to be bone dry to be paintable? And also that you have to pva it after its dry? Like i say, i have no clue when it comes to this stuff. :(
I'm sure there are proper ways of doing thigns like leaving it for a week before painting but in my own house I don't mind cutting corners like that and not had a problem yet (tempting fate...) you can underseal etc but I find a coat of paint does the same, as long as oyu realise it will be a basecoat not a topcoat!
Looks much better! The time it takes to dry varies based on lots of different factors from how it was mixed to the temp of the room but is normally a couple of days.
Thats odd because I just spoke to a plasterer about it as I presumed I was wrong given I've never plastered before but he pretty much agreed with me!!
Edited to say... sorry that sounds arsey, wasn't meant to!
