dump valve???
alan83
But you could change the position of the MAF sensor to after the turbo.
That way it will not matter if you have a non-recirc bov.
No you can't. You'll just heat it up and mess up the fueling...MAF's are heat based. A wire is heated up and as air flow increases it cools the wire and changes the resistance, this resistance is known by the ECU and it changes the fuelling to suit.
Put it in the heated airstream from the turbos will just screw all the figures.
If it didn't matter, toyota would probably have mounted it by the intake manifold....
