Daston Posted February 14, 2006 Share Posted February 14, 2006 Hi guys Got my new clutch and RSR GT fitted to day and must say I am well chuffed! One question tho is the baffle the thing that looks like a "mini exhaust" inside the rear silencer? If so how do I take it out as the guys at my garage didn't realise it came with one and just bunged it all in. Big thanks to Paul for great service as always! Quote Link to comment Share on other sites More sharing options...
uk-rich Posted February 14, 2006 Share Posted February 14, 2006 should be a small bolt, have a look under the exhaust at the back Quote Link to comment Share on other sites More sharing options...
Daston Posted February 14, 2006 Author Share Posted February 14, 2006 ah there is one under the front lip do I remove this then slide it out? I would post pics but its bloody dark Quote Link to comment Share on other sites More sharing options...
uk-rich Posted February 14, 2006 Share Posted February 14, 2006 front lip ? what do you mean ? Quote Link to comment Share on other sites More sharing options...
Daston Posted February 14, 2006 Author Share Posted February 14, 2006 where the silencer ends there is a steel rim at the bottom of that there is a small nut and bolt. Quote Link to comment Share on other sites More sharing options...
Homer Posted February 14, 2006 Share Posted February 14, 2006 Thats the one, undo the bolt and slide it out. You will have problems removing it for the first time when its one the car, they are fitted extremely tight. Most of us have had to hammer the things out from the other end (Obviously with it removed from the car!) Quote Link to comment Share on other sites More sharing options...
uk-rich Posted February 14, 2006 Share Posted February 14, 2006 baffles are for pussy's, get it out:D Quote Link to comment Share on other sites More sharing options...
Daston Posted February 14, 2006 Author Share Posted February 14, 2006 ok cheers guys will give it a go is there any way I can ease it up with out removing it or is it simple to take off with out the jack the car up?? Quote Link to comment Share on other sites More sharing options...
annan Posted February 14, 2006 Share Posted February 14, 2006 Its easy - there should be a bolt at the bottom of the 'mini exhaust' linking it to the big bore exhaust- undo the bolt- get a pair of pliers and pull the smaller 'mini exhaust tube out' this will leave the great big hole- and a great big noise- oh and you can take your stereo out cos you will not be needing it. Quote Link to comment Share on other sites More sharing options...
Homer Posted February 14, 2006 Share Posted February 14, 2006 Its easy - there should be a bolt at the bottom of the 'mini exhaust' linking it to the big bore exhaust- undo the bolt- get a pair of pliers and pull the smaller 'mini exhaust tube out' this will leave the great big hole- and a great big noise- oh and you can take your stereo out cos you will not be needing it. This is basically right, but there's no way mine would have come out like that from new. I had to use a 7ib sledge hammer and a block of 3x3 to hit get baffle out. That said, the noise difference with the baffle out is HUGE, especially on the RSR which has rather limited noise reduction Quote Link to comment Share on other sites More sharing options...
GazzaGSi Posted February 15, 2006 Share Posted February 15, 2006 Get that f'n thing out!!! You'll also have a better looking exhaust then as wel as the size of the tail pipe wont be a 2p coin Quote Link to comment Share on other sites More sharing options...
Conrad Posted February 15, 2006 Share Posted February 15, 2006 Bit of a thread hijack but thought I'd ask - sorry I'm getting an RSR exhaust next week and was wondering about the baffle. You see I don't like ridiculously loud exhausts! I'm a shy kinda guy and don't like too much attention, that's why I drive a Sup! Should I put my baffle in then? Will it affect performance in any way? Quote Link to comment Share on other sites More sharing options...
GazzaGSi Posted February 15, 2006 Share Posted February 15, 2006 Dont know about performance as i took mine out before it was even fitted, I wouldnt of thought so though. If you have a decat you may want to keep the baffle in. I have a decat and baffle out and it is loud and deep. Drowns my mates flat four rumble out completely and scoobs are loud with a decent exhaust. Quote Link to comment Share on other sites More sharing options...
MKIVDreamer Posted February 15, 2006 Share Posted February 15, 2006 IIRC removing the baffle will result in slightly reduced back pressure, performance gains can occur from this, but will be minor...as in very small. Exhaust noise will however increase, and as we all know: Louder zorst=faster car Right? Quote Link to comment Share on other sites More sharing options...
dangerous rep Posted February 15, 2006 Share Posted February 15, 2006 got my rsr from paul and took his advise and bashed it out first thing i did. it is loud i wont lie to you but damn its a good sound!! cheers again paul . may be looking for a splitter of you soon Quote Link to comment Share on other sites More sharing options...
paul_y3k Posted February 15, 2006 Share Posted February 15, 2006 i lveo the sounds, but I found that at certain speeds the reasonace was too painfull for any kind of distance. I did 30 odd miles on the m5 at around 80 and it was too mcuh. So I've stuck the baffle in and now in car is more than bearable, and I'm told that it's not noticalbly queiter outside as well. Quote Link to comment Share on other sites More sharing options...
monkey76364 Posted February 15, 2006 Share Posted February 15, 2006 If any one has a spare RSR baffler send it my way ...im still looking for one lol But god i remember the trouble i had getting mine out at first.... tons of WD40 and a big pair of pliars in the end lol. Quote Link to comment Share on other sites More sharing options...
Conrad Posted February 15, 2006 Share Posted February 15, 2006 GazzaGSi - Dont know about performance as i took mine out before it was even fitted, I wouldnt of thought so though. If you have a decat you may want to keep the baffle in. I have a decat and baffle out and it is loud and deep. Drowns my mates flat four rumble out completely and scoobs are loud with a decent exhaust Well it's those stupidly loud flat fours that put me off loud exhausts altogether. Don't get me wrong, I like the Scooby gurgle, just not when it's chavin loud! Do you guys reckon it's easy to put the baffle back in with the exhuast on the car? I might just remove the baffle and if it's too loud for my taste I'll put it back in. Quote Link to comment Share on other sites More sharing options...
monkey76364 Posted February 15, 2006 Share Posted February 15, 2006 I used to put mine in and out all the time ....ohh sounds fun lol. but serious once it has been in and out a few times its easy t do, and you will find the best way to get it in after a while, i used to just leat the exhaust warm a bit 1st so it expanded just that tad then put wd40 on the baffler and slide it in, it smoked abit at 1st but was the best way i found. Untill the day i forgot to put the bolt in and it flew out at 60mph and lost for every ...hence looking for a new one to replace it. Quote Link to comment Share on other sites More sharing options...
Conrad Posted February 15, 2006 Share Posted February 15, 2006 Good stuff. I'll pull mine out then. If I don't like it then i'll lube the hole up and slide it back in! Quote Link to comment Share on other sites More sharing options...
monkey76364 Posted February 15, 2006 Share Posted February 15, 2006 Good stuff. I'll pull mine out then. If I don't like it then lube the hole up and slide it back in! it will be lot louder...you wont belive the difference !! and as for the lube side...im saying nothing Quote Link to comment Share on other sites More sharing options...
GazzaGSi Posted February 15, 2006 Share Posted February 15, 2006 Well it's those stupidly loud flat fours that put me off loud exhausts altogether. Don't get me wrong, I like the Scooby gurgle, just not when it's chavin loud! I know what you mean, but from these its a different kind of loudness. The scoobs have a right rasp to them where as these the noise is ultra deep, On tick over I stand near the back of my car and I can feel the floow vibrating! Like youve said, take it out, see if you like it and if ya dont slip it back in. Ive had numerous people say to me who've been behind it sounds like an f1 car lmao Quote Link to comment Share on other sites More sharing options...
Daston Posted February 15, 2006 Author Share Posted February 15, 2006 Is using WD40 safe? Dont want to set fire to my zorst when firing up the first time. I got some massive locking pliers tonight so may eat some weetabix tomorrow and give it a go when I get back from work. Quote Link to comment Share on other sites More sharing options...
Homer Posted February 15, 2006 Share Posted February 15, 2006 It will be fine, just don't go mad with it Quote Link to comment Share on other sites More sharing options...
Daston Posted February 15, 2006 Author Share Posted February 15, 2006 Ok if there is a loud bang and all you can see to the south is black smoke it will most likly be me. Quote Link to comment Share on other sites More sharing options...
