Supra-Dupra Posted February 13, 2006 Share Posted February 13, 2006 Just fitted it, same result as last time revs go down to 340 yes 340, then turning off and the car wont go over 30-35mph am I suppose to be reading the instructions upside down as my loom is 2 together on left and 1 on the right ! This instructions is 2 on right 1 on left. INSTRUCTIONS: http://www.mkivsupra.net/vbb/attachment.php?attachmentid=28352&d=1139491009 Mines like this: Quote Link to comment Share on other sites More sharing options...
Jake Posted February 13, 2006 Share Posted February 13, 2006 The one in the picture is the same as yours Quote Link to comment Share on other sites More sharing options...
Supra-Dupra Posted February 13, 2006 Author Share Posted February 13, 2006 Anyone ?????????????? Quote Link to comment Share on other sites More sharing options...
Supra-Dupra Posted February 13, 2006 Author Share Posted February 13, 2006 So is the one in the picture! So the instructions are upside down then !!! Quote Link to comment Share on other sites More sharing options...
Jake Posted February 13, 2006 Share Posted February 13, 2006 No mate, it's correct. Quote Link to comment Share on other sites More sharing options...
Supra-Dupra Posted February 13, 2006 Author Share Posted February 13, 2006 No mate, it's correct. Well then it just faulty ! As both myself and a mechanice have tried it, and had it replaced already ! Quote Link to comment Share on other sites More sharing options...
Jake Posted February 13, 2006 Share Posted February 13, 2006 Does this make it any clearer for you? http://img438.imageshack.us/img438/7463/0003nu.jpg Quote Link to comment Share on other sites More sharing options...
Supra-Dupra Posted February 13, 2006 Author Share Posted February 13, 2006 Does this make it any clearer for you? http://img438.imageshack.us/img438/7463/0003nu.jpg This is how its fitted at the moment ! Checked it for the last 15 mins, the first unit i recieved from thor was the same, when the mechanic fitted it, am seriously pissed off so im gonna leave it for another day as Ill just bin it if I look at it tonight ! Quote Link to comment Share on other sites More sharing options...
Supra-Dupra Posted February 13, 2006 Author Share Posted February 13, 2006 Pin 70 beside ground, has no cable is this correct ? (blanked off also) Quote Link to comment Share on other sites More sharing options...
letmeshowyou Posted February 13, 2006 Share Posted February 13, 2006 are you sure? It would seem a common mistake to wire it in to pin 63 (as 61 is blanked off on most/all cars) Quote Link to comment Share on other sites More sharing options...
Supra-Dupra Posted February 13, 2006 Author Share Posted February 13, 2006 are you sure? It would seem a common mistake to wire it in to pin 63 (as 61 is blanked off on most/all cars) ye m8 i noted the blanked off pin holes, they have small white circular plugs Quote Link to comment Share on other sites More sharing options...
Guest Flat4_ire Posted February 13, 2006 Share Posted February 13, 2006 ye m8 i noted the blanked off pin holes, they have small white circular plugs thats a head wrecker, ring him up and snap! Quote Link to comment Share on other sites More sharing options...
Supra-Dupra Posted February 13, 2006 Author Share Posted February 13, 2006 Ill recheck again morrow with a clearer head, the rage is just kicking in thanks anyway lads ! Quote Link to comment Share on other sites More sharing options...
Supra-Dupra Posted February 13, 2006 Author Share Posted February 13, 2006 My problem lies at the map wire , as the power is in the unit ! Quote Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted February 13, 2006 Share Posted February 13, 2006 Only thing that I can think of is that you might have the blue and green wires round the wrong way? i.e. the input and ouput switched? Without looking it is difficult to tell. Quote Link to comment Share on other sites More sharing options...
Supra-Dupra Posted February 13, 2006 Author Share Posted February 13, 2006 Only thing that I can think of is that you might have the blue and green wires round the wrong way? i.e. the input and ouput switched? Without looking it is difficult to tell. I did check that multiple times tbh !! Id say its one of the following: 1. I overlooked a blanked out pin 2. Faulty unit 3. Green/Blue Crossed (gonna check that right now) As I have had it returned already, I find it hard to believe the second one is now faulty, so Im hoping its #1 ! Quote Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted February 13, 2006 Share Posted February 13, 2006 I did check that multiple times tbh !! Id say its one of the following: 1. I overlooked a blanked out pin 2. Faulty unit 3. Green/Blue Crossed (gonna check that right now) As I have had it returned already, I find it hard to believe the second one is now faulty, so Im hoping its #1 ! Try and get a photo of it wired in, so we might be able to have a look to see what you have done. Quote Link to comment Share on other sites More sharing options...
Supra-Dupra Posted February 13, 2006 Author Share Posted February 13, 2006 Try and get a photo of it wired in, so we might be able to have a look to see what you have done. Just check it now Green runs to the end of the map cable that heads into the loom of wires running through to the engine, the blue is connected to the end of running into the ECU pin Quote Link to comment Share on other sites More sharing options...
Supra-Dupra Posted February 13, 2006 Author Share Posted February 13, 2006 Try and get a photo of it wired in, so we might be able to have a look to see what you have done. Will get one in daylight ! Camera isnt great at night Quote Link to comment Share on other sites More sharing options...
Jake Posted February 13, 2006 Share Posted February 13, 2006 The MAP sensor wire is black and yellow striped. Is that definitely the one you cut? Quote Link to comment Share on other sites More sharing options...
Supra-Dupra Posted February 13, 2006 Author Share Posted February 13, 2006 The MAP sensor wire is black and yellow striped. Is that definitely the one you cut? Ehhhhh ill go check now !! Quote Link to comment Share on other sites More sharing options...
Supra-Dupra Posted February 13, 2006 Author Share Posted February 13, 2006 Yes its connected to the black and yellow striped , both wires (green and blue) Quote Link to comment Share on other sites More sharing options...
Jake Posted February 13, 2006 Share Posted February 13, 2006 Well at least you know that isn't the problem. Quote Link to comment Share on other sites More sharing options...
Supra-Dupra Posted February 13, 2006 Author Share Posted February 13, 2006 Well at least you know that isn't the problem. Ye m8, one ruled out at least cheers. And its definately grounded and running to the correct 12v pin ! Lookin like a faulty unit !! Quote Link to comment Share on other sites More sharing options...
Sub_Culture Posted February 13, 2006 Share Posted February 13, 2006 The MAP wires i black with a yellow stripe. I fitted mine at the weekend, Took me no time at all. Very simple. Any hassles, pop me a PM and I can talk you through how I did it. Andy Quote Link to comment Share on other sites More sharing options...
