Boost Controller Install
Supra-Dupra
The one that John is showing you, is the one that tells the unit what boost level you are running at, it then sends the signal to the little box with two pipes, to allow flow. This then opens your wastegate releasing exhaust gas.
You need to connect the other 2 pipes to the wastegate actuator of the front tubby.
Ok, pics please of this then ! Sorry but Im not a mechanic, I had a mechanic fit it but he was unsure of which hose is which so is all fitted bar the hoses plugged into these 3 places !
