lambertpig Posted February 13, 2006 Share Posted February 13, 2006 still not sure if my rltc works the unit has socket for second plug in is this needed to work ? have no diagnostic green led and the red dash led never lights up in any position ???? Link to comment Share on other sites More sharing options...
lambertpig Posted February 13, 2006 Author Share Posted February 13, 2006 anyone know? Link to comment Share on other sites More sharing options...
lambertpig Posted February 13, 2006 Author Share Posted February 13, 2006 30 veiws and no clues? Link to comment Share on other sites More sharing options...
Matt Harwood Posted February 13, 2006 Share Posted February 13, 2006 Well, certainly the serial lead and diagnostics plug isn't there, but that shouldn't stop it from working. The lack of red LED could simply ba a bad connection or blown LED. The only real way to tell is to get someone that's famillier with how RL works to either plug in a laptop and watch what's going on, or drive the car. Turning the adjuster fully clockwise should set it to it's most sensitive, 'Wet' setting. Link to comment Share on other sites More sharing options...
lambertpig Posted February 13, 2006 Author Share Posted February 13, 2006 thganks. i think it may be working as its not bad out of wet corners on power.a couple of last questions. as unit is connected to ecu injectors would this disable factory unit? and does the standard traction give the distant popping sound when kicking in? i know some traction control is going on Link to comment Share on other sites More sharing options...
merckx Posted February 13, 2006 Share Posted February 13, 2006 Connecting the RLTC doesn't automatically disable the factory unit, they don't operate the same way. The standard TC doesn't give you the popping sound but the RLTC can. The standard TC reduces the air supply to the engine and you lose a significant amount of power. The RLTC works much quicker and often will not give the standard TC a chance to operate . You should feel the RLTC working when you've got it on the wet setting, but on the dry setting it's not so noticeable. I switch off the standard traction control everytime I get in the car. Link to comment Share on other sites More sharing options...
Shaun. Posted February 14, 2006 Share Posted February 14, 2006 According to the install instructions (on MKIV site) it says remove the old TC unit as it is no longer needed, thus eliminating the need to turn on/off standard TC. I take it that this is a recommendation from MKIV and not on the RL fitting guide ? Shaun. Link to comment Share on other sites More sharing options...
