Jonny5 Posted February 12, 2006 Share Posted February 12, 2006 I'm going to wire up an apexi SAFC 2 as an addition to the HKS VPC already fitted, mainly to gain better control of the fueling. Do I use the signal from the VPC that would normally feed the HKS GCC unit? Or do I break the map sensor signal going to the VPC and redirect this to the SAFC then back to the VPC? Can anyone help.. Link to comment Share on other sites More sharing options...
LeeT Posted February 12, 2006 Share Posted February 12, 2006 the safc should be fitted on the output wire of the VPC Link to comment Share on other sites More sharing options...
Jonny5 Posted February 12, 2006 Author Share Posted February 12, 2006 cheers Leett... so just to confirm lol the yellow wire from the VPC that goes to the ECU will go to the input (white wire) on the SAFC, then (yellow wire) from SAFC back to ECU. fingers crossed.. Link to comment Share on other sites More sharing options...
LeeT Posted February 12, 2006 Share Posted February 12, 2006 cheers Leett... so just to confirm lol the yellow wire from the VPC that goes to the ECU will go to the input (white wire) on the SAFC, then (yellow wire) from SAFC back to ECU. fingers crossed.. yep, yellow wire into safc then output wire back to ECU Link to comment Share on other sites More sharing options...
Jonny5 Posted February 12, 2006 Author Share Posted February 12, 2006 sorted cheers M8:thanku: Link to comment Share on other sites More sharing options...
