Help!!! :o(
Peter P
H E L P ! !
I lost power last night and managed to limp home! idle is really lumpy and it's spewing out sooty deposits from the exhaust (literally small lumps of carbon).
Any ideas what this could be?! thinking turbos as it's a black smoke and can't see any other faults???
All help appreciated peeps.
Cheers,
Pete
That really sounds to me like your intercooler pipes have popped off.. did you give your car a blast on the road before you lost power?
black smoke is usually a sign your car is running very rich, and over fueling... its the blue smoke you need to worry about
also ive just taken the CATS off a car with broken turbos and there were black pieces of blade there. As my old car was fully decatted that would explain it just spitting the pieces out. hope you get it sorted mate.
oh yeah it does have stage three hybrids on there dont listen to me then
Looks like it was a pure overfueling issue and with a couple of loose pipes fitted back properly and the intercooler pipe sleeves all replaced and re-connected the car is running fine again! :)
Thanks to all of you for your advice/tips and hopefully she'll be ok now.
Cheers,
Pete :D
