Uprated fuel rail - is it worth it?
Homer
Guest Terry S
Just so its clear to a numpty like me - do you mean that the stock rail is twin feed or is some modification required? I.e. can I just drop in 650 injectors (with no other hardware) and just use an emanage to trim the fuel back?
Yes. Dual feed is just the radiator end of thr fuel rail adapted to take a feed, making the stock rail fed from both ends.
Okay, so the stock fuel rail requires some changes to make it feed from both ends, is that correct? Can you (Vortex) supply the parts to do this, and can it be done while the injectors, etc are still stock?
Guest Terry S
Yes mate, modified to be dual feed, & we can do an exchange rail. Injectors will make no difference, but TBH I wouldnt bother changing the rail until you upgrade injectors. Just making more work for yourself.
BTW, I am pretty sure the normal rail will flow enough for 650cc's without going dual feed.
