How to check fuel pressure on Aeromotive fpr
Homer
Put the small gauge on the front (if it's not already)
Start the engine, pull off the vacuum reference line. Note pressure, adjust if needed, put hose back on.
Personally I left the pressure gauge on all the time....
That's not actually the correct way to do it. Static fuel pressure should be set without the engine running. What you need to do is run the fuel pump with the engine not running and check the pressure. To do that you connect the +B and FP pins on the diagnostics port in the engine bay and turn the ignition on.
