lambertpig Posted February 10, 2006 Share Posted February 10, 2006 dont laugth but how do you convert boost psi to bar Link to comment Share on other sites More sharing options...
jamesmark Posted February 10, 2006 Share Posted February 10, 2006 look at your tyre pump............sorry lazy answer Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 10, 2006 Share Posted February 10, 2006 One PSI is 0.06894757 BAR You need "Convert". ftp://ftp.chriswilson.tv/convert Link to comment Share on other sites More sharing options...
Shaun. Posted February 10, 2006 Share Posted February 10, 2006 Link to comment Share on other sites More sharing options...
jamesmark Posted February 10, 2006 Share Posted February 10, 2006 you know i was just about to post that ............honest Link to comment Share on other sites More sharing options...
geoffvalenti Posted February 11, 2006 Share Posted February 11, 2006 One PSI is 0.06894757 BAR You need "Convert". ftp://ftp.chriswilson.tv/convert Cheers Chris Great little utility Link to comment Share on other sites More sharing options...
JamesG Posted February 11, 2006 Share Posted February 11, 2006 My favourite way is to use google. Try: 18 psi in bar 3 miles in furlongs speed of light in km/h Link to comment Share on other sites More sharing options...
dangerous brain Posted February 11, 2006 Share Posted February 11, 2006 1 bar is 14.7 psi http://www.onlineconversion.com Link to comment Share on other sites More sharing options...
Guest Terry S Posted February 11, 2006 Share Posted February 11, 2006 1 bar is 14.7 psi http://www.onlineconversion.com Thought it was 14.5 psi Link to comment Share on other sites More sharing options...
Lucifer Posted February 11, 2006 Share Posted February 11, 2006 Defo 14.7 as far as I was aware... Atmospheric pressure is 14.7 at sea level or 1013 millibars Link to comment Share on other sites More sharing options...
Ian C Posted February 11, 2006 Share Posted February 11, 2006 Thought it was 14.5 psi It's 14.7 - we just use 14.5 for fag packet calcs as it's easier for the brain to work with and makes no difference in the 0 to 3 bar range we ever work in -Ian Link to comment Share on other sites More sharing options...
dangerous brain Posted February 11, 2006 Share Posted February 11, 2006 Lol makes a rather dangerous difference at 3-4000 psi Link to comment Share on other sites More sharing options...
lambertpig Posted February 11, 2006 Author Share Posted February 11, 2006 cheers guys ive got the idea Link to comment Share on other sites More sharing options...
bedlam Posted February 11, 2006 Share Posted February 11, 2006 http://www.britishmetrics.com/html/tech_1.htm Link to comment Share on other sites More sharing options...
Syed Shah Posted February 12, 2006 Share Posted February 12, 2006 It's 14.7 - we just use 14.5 for fag packet calcs as it's easier for the brain to work with and makes no difference in the 0 to 3 bar range we ever work in -Ian 14.5 according to CW's answer above. Link to comment Share on other sites More sharing options...
Lucifer Posted February 12, 2006 Share Posted February 12, 2006 PSi, Commonly used in the U.S., but not elsewhere. Normal atmospheric pressure is 14.7 psi, which means that a column of air one square inch in area rising from the Earth's atmosphere to space weighs 14.7 pounds. Normal atmospheric pressure is defined as 1 atmosphere. 1 atm = 14.6956 psi = 760 torr There are different types of measurement for for diffrernt tpes of pressure, however the dirrence is minimal, unless as stated your talking about 1000PSI! Link to comment Share on other sites More sharing options...
